ad: spiderbeam
Results 1 to 2 of 2
Thread: Antenna Modeling Software
    Default Antenna Modeling Software
    I have a general question about antenna modeling software. When I use formulas for wavelength using the value adjusted for velocity factor of .95 (234/Mhz for vertical 1/4 wave) the answer is shorter, and seems more accurate, than using modeling software. MMANA and others seem to use the speed of light in a vacuum and therefore give answers indicating longer antennas.
    Why is this; can it be adjusted in the programs?
    Extra research I've found that the velocity factor of .95 is for the wire; not in air which is actually .9997. Still don't know why MMANA doesn't consider this is calculation. I've selected cu wire for medium with little change.
    Quote Originally Posted by AF5AD View Post
