ad: sscomp
Results 1 to 2 of 2
Thread: Ameco TPA Preamp / Indoor Active Antenna
    Default Ameco TPA Preamp / Indoor Active Antenna
    Ameco TPA Preamp / Indoor Active Antenna. Like-new condition, used only a few hours. $50 + shipping.
    The Ameco TPA is a dual-function device. It is a sophisticated preamp covering 220 kHz to 30 MHz with over 20 dB gain. The preamp features dual-gate FET circuitry and accepts input from a longwire, 300 ohm or random wire antennas.
    When an outdoor antenna is not available you can use the TPA as an indoor active antenna by extending the 30 inch built-in telescopic whip! Input from external antenna and output to the receiver is RCA phono jack.
    This ad was posted by AG4F David L Salomon, Senoia, GA 30276,
    AG4F joined QRZ on: 09-15-2002 IP: 50.180.249.145
    If no email address or phone was given, click HERE to send AG4F a private message.
    Thank you
    Slowly after 15 years I am getting back into the hobby - Retirement might be the real deal
    Can you tell me if this unit requires a wall wart or batteries as far as power?
    I want to use it stand alone for a R-1000 or R-2000 receiver till I get the wires up next Spring
    Thanks 73 Packy
    A E 3 O
    This ad was posted by AE3O PAXTON E PICKRELL, MOUNT AIRY, MD 217715728,
    AE3O joined QRZ on: 10-04-2002 IP: 199.36.17.2
    If no email address or phone was given, click HERE to send AE3O a private message.
