How to go from Zero to Extra Class HAM radio license in 30 min or less
35 minutes if you add in the times it took to have the previous exam graded and then proceed with the next one.
My exam day (Jan 14, 2012) results essentially matched my practice test results:
32/35 for Tech (25/35 needed)
31/35 for General (25/35 needed)
43/50 for Extra (37/50 needed)
To put this prep work into some more perspective: myself and an older gentleman started the Tech at the same time; they had just finished grading my EXTRA exam when he handed in his TECH to be graded (and he failed but he didn't quit. He took it again right there. I ended up leaving before he finished the second attempt though and don't know how he prepped.)
I admit I can be gloriously lazy. So much so that I will put in the prep work to do something only ONCE lol.
There was also the factor of only one test exam date listed in the ARRL.COM website for my area. As an aside to this; the test fee is $15. Whether you take one test or two or all three. You have to pass the one you are taking to move to the next one. If you fail one you can repay then retake that test, pass and move to the next level without paying for that next level test.
BUT MOST OF ALL ............... going back to being gloriously lazy ...................... I didn't want to bother with remembering "Can I transmit on this frequency or not?"
I studied for a full month, nearly every day, about 1-1.5hrs when you average it out, per day. Originally I was going to study and learn and immerse myself in the theory of it all but to grasp all three levels in a month, despite the overlap in theory, was not something I wanted to do.
I used ONLY FOUR tools:
Tech study guide PDF: http://kb6nu.com/wp-content/uploads/...studyguide.pdf
General study guide PDF: http://kb6nu.com/wp-content/uploads/...StudyGuide.pdf
Extra study guide PDF: http://www.arrl.org/files/file/Instr...9jan-AD7FO.pdf
The QRZ Practice Tests: www.qrz.com (the key to it all). Skynet keeps track of how many questions you answer correctly. Take the tests until you have answered all the questions correctly at least once.
What I did was read thru each study guide WHILE taking the practice tests.
As I read more and more of the guide I would score better and better on the test.
Reason being that I would see the question several times and when I got to that question in the guide the correct answer would simply be reinforced in my mind.
The setup of the Extra guide lent itself very well to this approach.
You can also look up the answer as each question in the practice tests has its reference number and a quick search in the guide will take you right to that question.
I ended up doing a little bit of both where I would guess and eventually get better at remembering or just look up the question and then answer it.
I would recommend looking up the question and then answering as this reinforces the correct answer in your mind sooner. Then take more tests without looking things up.
All the questions are standardized as are the answers. Once you’ve taken enough tests you can even get to the point of filling in the correct answer without looking at the question. You can take a plain calculator ........ but you guessed it; I only used it once lol.
My Practice Test results:
TECHNICIAN (71.4% is passing) I ended up taking 48 practice tests
t2010 2011-12-14 04:57:59 60.00%
t2010 2011-12-14 05:07:15 74.29%
t2010 2011-12-14 05:15:39 62.86%
t2010 2011-12-15 17:02:02 68.57%
t2010 2011-12-15 17:17:12 71.43%
t2010 2011-12-15 18:25:57 97.14%
t2010 2011-12-16 21:25:06 82.86%
t2010 2011-12-16 22:20:00 71.43%
t2010 2011-12-18 07:29:02 80.00%
t2010 2011-12-18 20:35:44 88.57%
t2010 2011-12-19 02:14:54 91.43%
t2010 2011-12-19 04:24:43 91.43%
t2010 2011-12-19 04:35:43 88.57%
t2010 2011-12-19 04:55:49 94.29%
t2010 2011-12-19 05:05:49 85.71%
t2010 2011-12-19 05:14:49 100.00%
t2010 2011-12-19 05:21:47 88.57%
t2010 2011-12-19 21:41:11 100.00%
t2010 2011-12-20 05:41:37 82.86%
t2010 2011-12-20 16:54:04 97.14%
t2010 2011-12-21 05:56:34 97.14%
t2010 2011-12-22 17:52:25 80.00%
t2010 2011-12-23 03:50:16 91.43%
t2010 2011-12-23 16:50:43 80.00%
t2010 2011-12-23 19:09:43 82.86%
t2010 2011-12-25 00:37:49 88.57%
t2010 2011-12-25 04:07:09 97.14%
t2010 2011-12-26 05:06:53 97.14%
t2010 2011-12-26 23:33:31 85.71%
t2010 2011-12-27 17:50:09 91.43%
t2010 2011-12-28 05:29:26 85.71%
t2010 2011-12-28 16:27:24 85.71%
t2010 2011-12-29 16:37:09 88.57%
t2010 2011-12-30 15:24:33 80.00%
t2010 2011-12-31 16:23:06 91.43%
t2010 2012-01-03 04:16:39 91.43%
t2010 2012-01-03 19:37:35 91.43%
t2010 2012-01-04 19:36:56 82.86%
t2010 2012-01-05 23:08:17 82.86%
t2010 2012-01-06 02:42:33 91.43%
t2010 2012-01-07 03:42:03 97.14%
t2010 2012-01-08 23:30:37 77.14%
t2010 2012-01-09 04:05:09 97.14%
t2010 2012-01-09 21:28:56 88.57%
t2010 2012-01-11 01:42:42 91.43%
t2010 2012-01-12 00:12:50 91.43%
t2010 2012-01-13 02:57:48 82.86%
t2010 2012-01-14 20:49:28 74.29%
GENERAL (71.4% is passing) I ended up taking 57 practice tests
g2011 2011-12-19 21:50:08 42.86%
g2011 2011-12-21 17:47:07 65.71%
g2011 2011-12-21 22:20:41 51.43%
g2011 2011-12-22 03:13:45 45.71%
g2011 2011-12-22 17:16:47 48.57%
g2011 2011-12-22 19:10:28 65.71%
g2011 2011-12-22 22:03:49 65.71%
g2011 2011-12-23 01:02:14 74.29%
g2011 2011-12-23 03:41:05 77.14%
g2011 2011-12-23 16:43:29 82.86%
g2011 2011-12-23 17:30:00 71.43%
g2011 2011-12-23 17:36:59 65.71%
g2011 2011-12-23 17:56:08 71.43%
g2011 2011-12-23 19:01:10 57.14%
g2011 2011-12-25 00:59:06 74.29%
g2011 2011-12-25 01:24:19 60.00%
g2011 2011-12-25 19:23:57 65.71%
g2011 2011-12-25 19:49:46 71.43%
g2011 2011-12-26 01:59:28 68.57%
g2011 2011-12-26 02:51:20 54.29%
g2011 2011-12-26 04:47:43 74.29%
g2011 2011-12-26 05:32:57 85.71%
g2011 2011-12-26 17:53:12 88.57%
g2011 2011-12-26 18:55:59 80.00%
g2011 2011-12-26 23:39:39 82.86%
g2011 2011-12-27 01:34:18 85.71%
g2011 2011-12-27 06:05:53 68.57%
g2011 2011-12-27 06:12:26 85.71%
g2011 2011-12-27 21:52:41 88.57%
g2011 2011-12-27 22:04:56 85.71%
g2011 2011-12-28 16:50:42 88.57%
g2011 2011-12-29 17:43:15 88.57%
g2011 2012-01-01 02:16:13 85.71%
g2011 2012-01-03 04:04:55 77.14%
g2011 2012-01-04 20:19:42 74.29%
g2011 2012-01-05 23:17:22 68.57%
g2011 2012-01-05 23:24:33 65.71%
g2011 2012-01-05 23:30:23 74.29%
g2011 2012-01-06 01:47:53 62.86%
g2011 2012-01-06 01:56:56 82.86%
g2011 2012-01-06 02:05:01 82.86%
g2011 2012-01-06 03:10:27 82.86%
g2011 2012-01-06 16:03:36 77.14%
g2011 2012-01-06 20:30:53 80.00%
g2011 2012-01-07 02:40:16 85.71%
g2011 2012-01-07 03:33:46 88.57%
g2011 2012-01-07 15:01:41 91.43%
g2011 2012-01-07 21:08:22 85.71%
g2011 2012-01-08 02:06:19 82.86%
g2011 2012-01-10 05:51:48 74.29%
g2011 2012-01-10 18:20:54 77.14%
g2011 2012-01-11 02:13:07 85.71%
g2011 2012-01-12 03:39:09 77.14%
g2011 2012-01-12 20:04:25 85.71%
g2011 2012-01-13 17:06:52 77.14%
g2011 2012-01-14 04:46:57 88.57%
g2011 2012-01-14 20:48:05 71.43%
EXTRA (74% is passing). I ended up taking 50 practice tests
e2008 2011-12-22 22:35:40 42.00%
e2008 2011-12-23 17:49:43 48.00%
e2008 2011-12-25 04:29:32 52.00%
e2008 2011-12-26 01:20:31 40.00%
e2008 2011-12-27 00:06:54 36.00%
e2008 2011-12-27 01:12:31 46.00%
e2008 2011-12-27 02:00:39 50.00%
e2008 2011-12-27 05:56:42 50.00%
e2008 2011-12-28 16:20:16 46.00%
e2008 2011-12-28 21:53:08 48.00%
e2008 2011-12-28 22:23:22 48.00%
e2008 2011-12-29 15:57:46 52.00%
e2008 2011-12-29 18:36:12 58.00%
e2008 2011-12-29 21:23:22 68.00%
e2008 2011-12-29 22:39:23 48.00%
e2008 2011-12-30 14:56:58 52.00%
e2008 2011-12-31 15:01:55 46.00%
e2008 2011-12-31 15:52:30 54.00%
e2008 2011-12-31 18:43:52 58.00%
e2008 2012-01-01 01:12:43 48.00%
e2008 2012-01-01 02:27:56 58.00%
e2008 2012-01-01 02:41:20 60.00%
e2008 2012-01-01 04:30:47 72.00%
e2008 2012-01-01 22:06:20 76.00%
e2008 2012-01-01 22:41:54 80.00%
e2008 2012-01-02 03:32:50 68.00%
e2008 2012-01-03 03:58:31 62.00%
e2008 2012-01-03 19:28:25 76.00%
e2008 2012-01-04 19:31:01 68.00%
e2008 2012-01-04 20:10:38 84.00%
e2008 2012-01-04 22:11:34 74.00%
e2008 2012-01-05 03:57:17 82.00%
e2008 2012-01-05 05:02:29 82.00%
e2008 2012-01-05 05:55:13 80.00%
e2008 2012-01-05 23:02:52 86.00%
e2008 2012-01-06 01:38:35 88.00%
e2008 2012-01-06 02:27:33 88.00%
e2008 2012-01-06 04:56:50 78.00%
e2008 2012-01-06 19:28:17 84.00%
e2008 2012-01-07 02:52:03 88.00%
e2008 2012-01-07 15:36:55 72.00%
e2008 2012-01-07 16:28:36 82.00%
e2008 2012-01-08 02:28:59 66.00%
e2008 2012-01-08 02:59:28 82.00%
e2008 2012-01-09 00:34:41 86.00%
e2008 2012-01-10 18:54:50 88.00%
e2008 2012-01-11 02:41:03 84.00%
e2008 2012-01-11 22:38:56 84.00%
e2008 2012-01-12 20:53:59 82.00%
e2008 2012-01-14 20:51:30 72.00%
Reason: User Request
Outstanding! Now, put it to use! After all that hard work, I hope you have fun!
EchoLink, IRLP and DSTAR - adding interest to repeaters worldwide 24X7
I see this a lot, but it isn't totally correct. In the USA we have so many mode restrictions that they are just as important as the frequency restrictions. For example, no US ham can use SSB on 14.145MHz, and no US ham can use PSK on 14.255. These are just examples, most commonly used bands have these mode restrictions in force for all classes of licensees.
Joe
We cannot tax our way to prosperity.
Congrats! I just passed my Extra exam this morning and got my Tech and General on the same day about a month ago. I used the same technique and it worked great. I read the ARRL books for each license class while taking practice tests with the Patrick Maloney iPhone apps. I definitely recommend the books since I think it's important to actually understand rather than memorize, and the practice tests are great for reinforcing the material and telling you what needs repeated study. I see exactly the same sort of pattern as you with my practice tests. For example, it took me a while to pass my first Extra practice test, would sometimes fail after my first success, but I then passed thirty in a row as I completed the book and figured I was ready for the real thing and I was--I only got one question wrong.
Congratulations I also went from Zero to Extra in one sitting, passing all the tests the first time. .
AF6LJ
You cannot rule an educated population.
Danpass
Congrats and Welcome!
Now that you are an Extra will be expected to learn Morse Code and make your own tubes.
Mark, K8MHZ
"The best number is 73. Why? 73 is the 21st prime number. Its mirror (37) is the 12th and its mirror (21) is the product of multiplying, 7 and 3. ... In binary, 73 is a palindrome, 1001001 which backwards is 1001001."
-Dr. Sheldon Cooper, (Jim Parsons), "Big Bang Theory"
"Just to invite your attention to "73" in Morse code--also a palindrome."
-W9JEF
 Originally Posted by K8MHZ
Danpass
I downloaded some training programs that day
Congratulations AK4PX! Sweet call. Looking forward to working you.
Regards,
-Bruce
WE4AU
"QRN doesn't dare...ever. Smith charts, after month's of study, still can't comprehend me.
CMEs plan their outbursts around my operating schedule. I know what my equipment cannot do, and that's what I don't do."
- The Most Interesting Radio Amateur in the World.
Regards,
-Bruce
WE4AU
Agreed! I was eager to figure out a 4 character call when it finally showed up online but this one rolls nicely
Joe
Unless something has changed that I don't know of, you can use data modes in the phone sections, just not vice-versa.
