I dont consider a simple discussion a peeing war but if youre not able to offer more than that so be it.
I'm quite ABLE but UNWILLING to "discuss" this with you.
Finito (meaning, I won't be revisiting this thread again).
I guess thats better than having to admit making a mistake or accepting that there are other valid opinions in your eyes....SOP.
 Originally Posted by N7GTB
BTW, you're the second person to mention/recommend using a control board.
I've not had a chance yet to fully read up and understand their benefit.
In a nutshell, what function do they serve?
SIMPLIFICATION for the DIY Builder of the various Regulation, Control, Monitoring, and Display electronic circuits
of the RF Power vacuum tube operation in the linear RF amplifier.
There are 2 well known suppliers for control boards (DIY Builders):
One is Paul Hewitt, WD7S - who offers a Triode Control board as well as many other
assemblies/modules (band switchable tuned input) for the DIY Builder
http://home.earthlink.net/~wd7s/triode_control.htm
The other is G3SEK/GM3SEK in the UK, who offers a Triode and a Tetrode Control board (as well as kit of parts and board).
http://www.ifwtech.co.uk/g3sek/
 Originally Posted by AG6K
For a full 1000w in linear service, 6. 811As would be better since they have rather low anode dissipation capability and they are not very linear above 200mA. However, since each 811A has 0.6pf of C-feedback, you will be dealing with a total C-fb of 3.6pF - which means that you will need to use better than avg. - a.k.a., lower-Q - VHF suppressors to keep the squirrels away. With 6, 811As and minimal fil.-V your tubes should last a long time Vern.
• Rich, ag6k.
I stumbled into a few 811a's for not too much out of pocket... I also made a concerted effort to dig into my junk boxes...found ceramic sockets, and some other parts that I think might work. I'm intrigued by this and have decided to start working on it. I've also sent away for a Russian tube (GS35B). Once I have more time (this summer or next fall) I'll begin building around that tube as well...
I don't know if I'll manage 6 811As, but for the sake of argument seems like some increased airflow might be required...(?) 6 bottles in tandem sounds cool as all get-out.
Hi,
Great that you going for the 811a's! It would be great to know how it advances for you. Post some pics of the progress. Here is my 811 build: (almost done): http://gallery.me.com/ulf.tjerneld#100183
73's
Ulf
Good luck on that.
Four tubes require neutralization and barely work on ten meters.
Unless you plan on staying below 20 meters, I'd limit to 4 tubes.
 Originally Posted by W8JI
Good luck on that.
Shouldn't be too much of a problem... I seldom go up to 10m, and when I do my beam seems to get me anywhere I want to go. It's the lower bands where I would like the boost. 160m in particular is always a struggle... As I said, 6 tubes may be a bit much. By my calculations, the filaments alone will require 24 amps and I still need to come up with a suitable plate transformer for even four 811As.
I built a 6 tube 8-11 amp 25 years ago and was very happy with it at 15 and down. It did work on 10 but had problems. I just used it on 15 and down. It produced as expected with 1500 volts on the plate for an easy 750 watts and a stretch to hit a KW.
Joe
 Originally Posted by SM0NOR
Hi,
73's
Ulf
Great looking amp! I see the schematic for the power supply... do you have one for the amp that you'd be willing to share ?
Joe
Joe... Sent you a PM...
