Results 1 to 3 of 3
Thread: Hamtronics REP-100 Repeater for 220 Mhz
    Feb 2003
    Saxonburg, PA/Cairo, Egypt
    Default Hamtronics REP-100 Repeater for 220 Mhz
    For Sale
    Hamtronics REP-100 repeater currently set up for 220 Mhz. (Transmit 224.7 – Receive 223.1). This was a functioning repeater in the Pittsburgh area which was recently taken out service and stored by me till now. The unit is light and easily shippable.
    Subunits consist of:
    Hamtronics REP-100 chassis and front plate with speaker and controls – both TX and RX are fully shielded in aluminum specialty boxes atop the chassis.
    MAGGIORE ELECTRONIC LABORATORY Hi Pro R4V RECEIVER
    Present retail price from manufacturer - $267
    Website - http://www.hiprorepeaters.com/Receivers.htm
    Manual - http://www.saxonburgcommunications.com/rv4.pdf
    HAMTRONICS® T5I VHF FM EXCITER
    Manual - http://www.saxonburgcommunications.com/T51.pdf
    HAMTRONICS® LPA 2-15 LINEAR POWER AMPLIFIER
    Manual - http://www.saxonburgcommunications.com/LPA2-15.pdf
    Hamtronics Traditional CWID Module
    Specs - http://www.saxonburgcommunications.com/cwid.pdf
    Hamtronics COR module (probably COR 2 from the 80s)
    This unit has been tested only to the extent that the receiver is working, the transmitter is working and the CWID is working. Bench trials using test gear and the one 220 HT I have here indicate that the unit will function as a system as intended but I cannot guarantee that it is a totally fault free. The unit can be broken with the squelch set properly, transmits an ID and appears to switch properly.
    Consider it a project box that is near 100% and would be good for a club repeater or local community operation both on 220 or 144 (with 2 meter xtals). It runs from 12 volts DC and could easily be taken portable for special event or emergency situation support.
    Photos are at:
    https://picasaweb.google.com/kjsoren...eat=directlink
    $125 plus shipping CONUS, Postal Money Order
    kjsorenson@gmail.com
    Jim
    W3BH
    Saxonburg, PA
    This ad was posted by W3BH KIEF J SORENSON, SAXONBURG, PA 16056,
    W3BH joined QRZ on: 02-28-2003 IP: 24.154.51.44
    If no email address or phone was given, click HERE to send W3BH a private message.
    email sent
    This ad was posted by N6DBZ MICHEL TER SARKISSOFF, LINCOLN CITY, OR 97367,
    N6DBZ joined QRZ on: 11-26-2001 IP: 76.2.3.50
    If no email address or phone was given, click HERE to send N6DBZ a private message.
    Feb 2003
    This unit has been sold.
    Thanks for looking.
