I'm no antenna expert but I have restored a an old SYS33 antenna, (MACO Memphis TN). got it assembled and mounted on my Hazer. 10 and 15 Meters load up beautifully SWR near 1.0: 1. But 20 meters sucks pond water. Lowest SWR I can get is about 2:1 and that is less than 50 khz wide near 14.140 Mhz. Original test showed the antenna at 1.6:1 at approximately 13.97 Mhz indicating the 20 meter elements needed to be shorter, the farther up the band I have managed to move the near reasonance dip, the worse the SWR becomes. AM I dealing with a shorted trap coil here? Readings taken with a MFJ 259B give a 2.0:1 SWR at 14.144 mhz, Antenna R =38, X=29 while Xc =307Pf and Xl=O.345uL. Am I on the right track or is there some other problem I am over looking, any help is appreciated. Thanks Bill
