Results 1 to 2 of 2
Thread: Need Help on Cat Control with Icom IC-718
    Mar 2005
    Puerto Rico
    Default Need Help on Cat Control with Icom IC-718
    Hi Fellows;
    Anyone has set-up the cat control from the PC to the Icom IC-718, using a Rigblaster interface (USB Plug and Play)? Any hint will be appreciate.
    KP4RV - Rafael
    Rafael -
    RIGblaster Data Jack Plug & Play (Photo attached)
    http://www.westmountainradio.com/pro...roducts_id=pnp
    RIGblaster Data Jack Plug & Play -- MANUAL
    http://www.westmountainradio.com/pdf/ManualP&P.pdf
    Page 8 of MANUAL covers RIG CONTROL CAT/CIV, INSTALLATION AND SETUP
    Page 10 of this manual has an Icom cable wiring diagram --- IF you are a DIY cable builder. Otherwise purchase the cable you need.
    You may order a pre-wired cable from West Mountain Radio for rig control via the RIGblaster Plug & Play’s interface.
    If you wish to make your own cable look on West Mountain's Internet support page for instructions.
    Assuming you have a correctly wired cable connect it between the RIGblaster’s “RADIO” “RIG CONTROL” jack and the radio’s jack.
    Lower Right Jack on Rear Panel - IC-718.
    West Mountain Radio -- Support -- FAQs
    http://www.westmountainradio.com/content.php?page=faq
    ICOM IC-718 -- Instruction Manual
    http://www.icomamerica.com/en/produc...8/default.aspx
    MANUAL -- GO to PAGE 6, this shows the REMOTE (3.5 mm jack) on REAR PANEL of your Icom IC-718 .
    This is for Icom CI-V connection (Icom's name for Remote Control, Yaesu's name is CAT - Computer Assisted Tuning).
    Your RIGblaster Data Jack Plug & Play replaces the Optional Icom CT-17 : CI-V Level Converter -- shown on page 57 of the Manual.
