ad: CommRadio-1
Results 1 to 2 of 2
Thread: Ferrite core
    Default Ferrite core
    Trying to built balun say 4:1 for my ocf windom But no sure what of ferrite spec to use.understand there are quite a number spec. So anyone out there please if you would help me understand more of these ferrite for use with building a 4:1 Balun...
    De: 9M6BZ
    FOR EXAMPLE:
    Torroid core with part numbering : F-23-43
    F = Ferrite Toroidal
    23 = O.D. Dimension (Physical size of the core)
    43 = Material Type or Mix (suitable freqeuncy range)
    FULL Specfications (CWS ByteMark page) -- include the following characterisitics:
    AL( nH/Sq Turn) is the Al value. Required turn = square root of ( desired 'L' in nH / 'AL' in nh/Sq Turn)
    CWS ByteMark Part Number is the part number to use to place your purchase order
    O.D. is the outer diameter of the toroid core
    I.D. is the inside diameter of the toroid core
    Height is the height of the toroid core
    Material is the Ferrite material designator where you can look up its properties at www.bytemark.com
    Permeability is the Permeability of the materials
    CWS ByteMark - one supplier
    http://www.cwsbytemark.com/index.php...&cPath=206_221
    Fair-Rite Products --- Iron and Ferrite Cores
    http://www.fair-rite.com/newfair/index.htm
    It is always a good idea to LOOK at commercial products ... IF you are new to DIY Building.
    BALUN DESIGNS is one commercial company
    http://www.balundesigns.com/servlet/...uns/Categories
    KNOW (and see) the difference in QUALITY construction ---
    there are a number of COPY-CAT companies (no R&D or Quality Control)
    http://www.balundesigns.com/servlet/...late/Test/Page
    W8JI - Off-Center Fed (OCF) Dipole - Windom
    http://www.w8ji.com/windom_off_center_fed.htm
    W8JI - 4:1 Balun Design & Operation
    http://www.w8ji.com/balun_single_core_41_analysis.htm
