I also answered this in you other thread. And the comments made by others here is indeed correct. There is no need to even start HRD. If you do use HRD Log, you can enter the frequency via the Bulk Edit function (for those QSOs on the same frequency). For example, you just ran 20 QSOs on 14.070 and had them all automatically enter into your log in HRD logbook. You're going to quit for the day, so over in HRD Log, select those 20 QSOs my highlighting them using normal Windows functions. After they are highlighted, under MORE is the Bulk Editor. Select that and then follow the menu to add the Frequency to the QSOs. All done.
Not Socialism or Communism.
