Hello
I have recently purchased an 811H and I'd like to use it with my Yaesu FT-107M.
On the rear of the 107M is the only connection for an amp and it is a 5 pin din connector.
I do have an Ameritron ARB-704 which has a "Multi-Port" on the rear of the unit. I am hoping I can wire 2 RCA connectors to this 5 pin Multi-Port and run them to my amp. I just don't know
I am not familiar with amps at all as this is the first amp I have owned in 36 years as a ham.
The 5 pin din on the 107M is as follows:
1. -ALC IN
2. GND
3. TX GND
4. GND
5. RX GND
Below is a partial of the ARB-704 schematic with the output show.
Would someone be kind enough to tell me where to connect to run my 2 rca plugs to the 811H amp ALC OUT and Relay? Or.... Should I go in another direction? I sure would appreciate any help.
thanks
Jerry N1TKO
