Can't change my old call in logbook
Hello all,
I have two problems with my logbook:
1) When I make a logbookentry, my old call (PD5HA) appears. How and were can I change that.
2) In my logbook all the entries I made last two months, my own callsign is shown. If I however choose the option "manage logbook", the right spots appear. Does somebody know what the problem is?
Thanks and greetings
Harold
Dear Scott,
Thank you for your reply. I followed your suggestion but unfortunately my old callsign keeps appearing in my logbook. Strange thing is that when I use the button logbook in the upper toolbar next to the "manage" button, everything is shown correctly. But when I use the tab logbook in the lower/bottom toolbaar (biography/details/notes/logbook) my old callsign is shown in the column were the callsign of the person I had a contact with should be shown.
Do you have other ideas what could be wrong?
73’s Harold
"I've seen a couple of other posts like this, but the solution was hard to understand, but I figured it out. Next time you log a QSO look at the tabs on top, click the sender info tab and manually enter all the info you want, goto the bottom and click save, and that's it. The logbook saves the info from your last entry and applies it to the next. I guess that makes it easy if your working a specific band and freq and have 20 QSO's to log, you don't have to keep entering the same thing 20x's. 73 Scott."
