Dual Band Rigs (Mobile and HT), HT Accessories and VHF & UHF items
Dual Band Rigs (Mobile and HT), many HT Accessories,
and VHF/UHF related equipment for sale, such as DTMF
Touch Tone Microphones, Speaker Microphones, Wattmeters
/ SWR Bridges, Rubber Ducks, Protective Cases, Belt
Clips, Wrist Straps, and much more:
Kenwood TW-4100 A, Dual Band mobile FM transceiver For Sale:
The Kenwood TW-4100A is a high powered dual-band transceiver
providing 45 watts on 2 meters and 35 watts on 70 cm (440 MHz).
A low power setting of 5 watts may also be selected. Ten memories
with offset recall and lithium battery backup are provided. There
are separate antenna output jacks on the back panel for 2 meters
and 440 MHz. It is supplied with an MC-48, 16 key DTMF hand mic,
mobile mounting bracket and DC power cord. Requires 13.8 VDC at
7.5 amps.
Features
* Scanning
* Priority Watch
* Lithium battery backup
* Auto Repeater Offset
* MC-48 DTMF Microphone with up/down switches
This particular unit works great and looks fine. It has a
subaudible tone encoder added where the speaker would normally
be. An external speaker needs to be used with it.
With DTMF Mic, tone encoder, mobile bracket, power cord, and
paper work for $160.
Icom IC-281 H, 2 meter transceiver with 440 MHz receive
The Icom IC-281H 2 meter mobile FM transceiver boasts 50
watts output plus 440 band receive (440-450 MHz) for full
duplex crossband operation. Other features include 60
regular memories, 10 scratch pad memories, 14 auto dialer
memories, built-in pager and code squelch functions and
auto memory channel advance. The IC-281H is packet ready.
A data jack is available for direct TNC connection,
supporting speeds up to 9600 baud. It features a huge
heat sink. Requires 10.5 amps at 13 VDC.
Features
* 440 MHz Band Receive
* Tone Scan
* 60 Memories
* 10 Scratch Pad Memories
* Scanning
* Call Channel
* 50/10/5 Watts Output
* Auto Power Off
* Priority Watch
This one works 100% and looks extremely nice.
With mic, tone encoder, mobile bracket, power cord,
and paper work for $150.
Yaesu VX-3 dual band HT:
The compact VX-3R 2m/70cm FM HT Transceiver is loaded with
convenience features. In additon to top quality performance
on 2m and 70cm, you will also be able to enjoy stereo FM and
AM broadcast band reception.
The Yaesu VX-3R 2 meter/440 MHz handheld has extensive receive
frequency coverage, providing local-area two-way amateur
communications along with unmatched monitoring capability.
The VX-3R receives: 500 - 1800 kHz (AM Band), 1.8 - 30 MHz
(Shortwave), 30 - 76 MHz (VHF Lowband with 6M), 76 - 108 MHz
(FM band), 108 - 137 MHz (Air Band), 137 - 174 MHz (VHF High
band with 2M), 174 - 222 MHz, 222 - 420 MHz (VHF band with 220),
420 - 470 MHz (440), 470 - 800 MHz and 800 - 999 MHz (800 band
[cellular blocked]). You get a huge 1000 channel memory system.
Power output with the supplied Lithium Ion battery is 1.5 watts
VHF and 1 watt UHF. With the optional E-DC-21 DC adapter output
jumps to 3 watts and 2 watts!
This particular HT is like new. It works 100%, and looks like
new, with no scratches. It has its original box, rubber duck
antenna, LiIon Battery, charger, and paper work all for only $150.
Yaesu HT Accessories:
Yaesu E-DC-5 B Cigarette Lighter Cord
DC Cable with voltage regulation, filtering and cigarette
lighter plug. For many Yaesu handheld radios including
FT-530/415/50R/FT-60R, VX-5/VX6/VX-7/VX-8/VX-170, etc.
These sell new for $27. Buy this one for only $18.
Real Yaesu Battery pack for Yaesu VX-2 or VX-3 HT
FNB-82 LI Lithium Ion Battery Pack fits both the VX-2 and the
VX-3. 3.7 volts, 1000 mahr, works great, and holds a charge
like new. $22
Yaesu NC-18 B Charger
Provides 14.5 V DC at 50 ma to charge many different HTs,
including the Yaesu FT-411, FT-811, FT-911, FT-23, FT-209,
FT-415, FT-410, FT-470, FT-727, FT-530, FT-703, and more.
Small 2.5 mm male plug. $10
Belt Clip for Yaesu FT-207, with hardware. $8
Wrist Strap for Yaesu FT-209, and probably others $4
Miscellaneous Icom Accessories:
Icom DC-25 DC Adapter
This is a pack that is used on the Icom µ2AT, Icom µ4AT, and
on other HTs that use the BP-20, BP-21, BP-22, BP-23 and BP-24
battery packs. It takes 13 V DC (such as from a cigarette
lighter), and converts it to the 9.4 V DC voltage needed for
the HT. It is used in place of a battery. This one works
fine and looks fine. $20
Icom BP-21
This battery pack is DEAD and sold for rebuilding, building
a DC converter, or whatever. $10
Icom BP-22
Icom BC-110 A, Wall Wort Charger:
It produces 12 V DC at 200 ma.
I am not sure of all the units that use this charger. I know
it is used by many of the aircraft HTs, and also to charge the
R-10, T2H, T7H, T70, T80AD, T90A, T91A, T92AD, W32A, and I am
sure others. Apparently it is also known as a BC-167 in
addition to BC-110 A. This is NOT one of the switching units,
so you will not have RFI from this one.
This one works fine and appears very close to new.
Icom charges almost $40 for this. Buy this one for $15
Icom BC-127 A, Battery Charger for Icom IC-Q7A
Dual Band HT:
This charger charges two AA NiCads (or NiMH) for the
IC-Q7 A Dual band HT, and Icom R-2 receiver, and probably
others.
This appears to be new, unused, still in its bag.
Icom lists them at $21.
Buy this one for $12 plus shipping from Florida.
DTMF Touch Tone Microphones:
Kenwood MC-46 DTMF Touch Tone Microphone
Touch tone DTMF microphone with 6 pin connector, as used on
TR-7730, TR-7800, TR-7850, TR-7930, TR-7950, TR-8400, TR-9000,
TR-9130, and others. Up-down switch on top. 16 digit touch
tone pad. This one works fine, and includes paper work for $40.
Kenwood MC-48, DTMF Touch Tone Microphone
Round, 8 pin connector, will go with any Kenwood rig taking
this kind of connector (TM-201, TM-211, TM-221, TM-231,
TM-241, TM-2530, TS-50, TS-430, TS-440, TS-570, TS-850, TS-870,
TS-930, TS-940, TS-950, TW-4000, etc.). Has UP and DOWN
switches and PTT, along with 16 digit touch tone pad.
This one works fine, and looks extremely nice.
With paper work for $45.
CES 610 L DTMF Touch Tone Mic
Can manually dial a number, or automatically store it in
the mic, and "speed dial". 12 digit touch tone pad on the
front. 8 pin modular plug (like computer LAN).
Looks to be new. $38
KDK DM TT-1 DTMF Touch Tone Mic
This mic has a 12 digit touch tone pad on it, with a
switch to turn the pad on and off. With 4 pin plug.
It works fine, and looks great. $35
KDK Model TM-2 DTMF Mic
With touch tone pad and up-down switches. It presently
has stripped and tinned ends. Nice condition. $35
Johnson 250-0761-010 / CES 655 L DTMF Mic
It has a 12 digit pad on the front, and is a rugged mic.
Presently with 4 pin plug. Looks to be unused. $38
HT Speaker Microphones:
Azden SDX-316 Speaker Microphone
Although it has an Azden name plate, it will also work
with Icom, some Yaesu, and Alinco that need 3.5 mm and
2.5 mm plugs.
This is the rounder style speaker mic that fits nicely in
the palm of your hand. $20
MFJ 286 Speaker Microphone
This was used on a Kenwood TH-225 HT, but it also fits the
TH-21/31/41 series HTs, TH-205, TH-215, TH-415, as well as
others. It has a 3 conductor 3.5 mm plug and a 2 conductor
2.5 mm plug. It works fine. $12
MFJ-287 Speaker Microphone
Fits same HTs as the MFJ 286 above, but is a smaller more
compact speaker mic. It works fine, and looks close to new. $15
Wattmeters:
HF Dual Meter Wattmeter:
Micronta 21-520 A Dual Meter HF Wattmeter:
Full scale readings of 10, 100 and 1000 Watts. It has a
remote pickup sensor with about 3 feet of cable to the
dual meter control head. It reads both SWR and forward
watts at the same time, on the dual meters, which are
fairly large. This one is in extremely nice, close to
new, shape. $55
Heath HM-2102 VHF Wattmeter:
Covers 50 to 160 MHz with SO-239 connectors in and out.
Similar to the HM-102, but for VHF frequencies, with 250
and 25 watt scales. It can also be used to check SWR, and
has a remote sensor that can either be left inside the
meter, or separated from the actual meter.
This particular meter works great. It looks very close to
perfect with no defects that I can find.
Paper work included for $45.
SWR Bridges:
Both of these cover from 3 to 150 MHz, covering HF, 6 meters,
and 2 meters, so are ideal for the new rigs with 6 meters and
2 meters in them. SO-239 connectors.
Quement SWB-2
This unit features two separate meters -- one for reading
forward power and another for reading SWR. This permits one
to easily monitor both the power going out, and the SWR on
the antenna at the same time.
It works fine and looks great. With paper work for $40.
Royce 2-100 Single Meter SWR Bridge / Field Strength Meter
This one works fine, and looks extremely nice. I do not see
any scratches on it, but it does have a previous owners name
on it. In its original box with original instructions. $32
Rubber Duck antennas for your HT:
All are for 2 meters, are in good condition,
and are $10 each, unless stated otherwise.
BNC - About 7 inches long
BNC - Original from Kenwood TH-215, about 5 inches long
BNC - Stubby about 4.5 inches long
5/16 inch threaded, as used by Motorola and others
Stubby - 4 inches long
Type F connector - 6.5 inches long
PL-259 connector - 6.5 inches long
HyGain 275, still in original packaging
PL-259 connector - Stubby - 4.6 inches long
Centurion, still in original package
Special for Kenwood TH-21 HT threaded connector
Stubby, about 4.5 inches long - $20
BNC Stubby for 440 MHz, 3 inches long
Protective Cases:
Kenwood SC-13 Vinyl Case
For TH-215, TH-225 and others, with room for the larger
PB-1 and PB-4 battery packs. It can also be used with
the smaller PB-2 and PB-3 packs. Black color. Great
condition. $15
Case for Drake TR-33C
This is the black case that fits the Drake TR-33C, and has
cutouts in the back for antenna, power, etc. It includes
the shoulder strap, and is in good shape. $12
Case for Drake TR-22
As above, but for the TR-22. No shoulder strap. $10
Leather Case for Santec HT
This is a real Bianchi Leather case -- not a vinyl case.
It fits most of the Santec HTs, such as the HT-1200,
ST-142, ST-144, ST-440, etc. The real leather case
includes a built in belt clip, plus a removable leather
shoulder strap. $25
Accessories for Kenwood TH-205, TH-215, TH-225, TH-415,
and other HTs in that series:
condition. $15
Kenwood Wrist Strap for TH-215, plus many other HTs. $4
Original Kenwood Rubber Duck antenna from TH-215. $10
Kenwood BC-2 Charger for PB-2 batteries. $12
BNC to PL-259 antenna adapter $5
Accessories for the Kenwood TH-21 / 31 / 41 series HTs:
Kenwood BH-3 belt clip and hardware for Kenwood TH-21 / 31 / 41
series HTs. $8
Kenwood W09-0315 charger
This charger is used to charge the larger PB-21 H batteries
for the TH-21 series, and also on other Kenwood radios.
It produces 10.5 V DC at 42 ma, with a standard 2.1 mm
coaxial connector. $12
DEAD Kenwood PB-21 battery pack
This battery pack is used on the TH-21 series HTs. This one is
dead, but can be used for rebuilding. It is in good physical
condition, with no cracks. $10
Kenwood Rubber duck antenna for the TH-21 HT
Shorter "Stubby Duck" from Kenwood. $20
Drake items:
Case for Drake TR-33 C, 2 meter transceiver
This is the black case that fits the Drake TR-33 C, and has
Case for Drake TR-22, 2 meter transceiver
3 pin mic plug for TR-22, 2 meter transceiver
This is the small 3 pin mic plug that fits the Drake TR-22
mic jack. It is much smaller than most of the mic connectors.
This one has been used, but should still be usable some more. $10
Accessories for the Azden PCS-300 HTs:
Azden SDX-316
the palm of your hand. Has 3.5 mm and 2.5 mm plugs for
Azden, Icom, some Yaesu, and others. It works great, and
looks great also. $20
Battery charge adapter for Azden PCS-300 HT
This is an adapter that permits one to charge the battery
of the Azden PCS-300, 2 meter HT, outside of the HT itself.
Usually, one must have the battery inside the HT, but this
lets you charge a second battery outside of the HT. The
original charger is used. If you have a PCS-300 HT, you
need this adapter.
It works fine, and looks like new. $3
Antenna adapter to fit the BNC connector on the HT and provide
an SO-239 connector that will permit a PL-259 to be attached.
This adapter can be used on any HT with a BNC connector. $5
Santec HT Accessories:
shoulder strap.
The case itself is in very nice shape. The leather
shoulder strap has not been used. $25
Santec ST-142/144 "Service Pack"
This is similar to a service manual, but Santec calls it a
service pack. It has schematics, circuit explanations,
voltages, etc. $18
Lithium Ion Battery Pack that fits both the VX-2 and the VX-3
3.7 volts, 1200 mahr, works great, and holds a charge like new.
$15
HT Belt Clips and Wrist Straps:
Belt Clips:
All include the hardware with the belt clip and are $8 each.
Kenwood BH-3 for Kenwood TH-21 / 31 / 41 series HTs
Motorola
Yaesu FT-207
Wrist Straps for various HTs - $4 each
Kenwood TH-215 / 225 / 415, TR-2500, etc.
Kenwood TR-2400
Yaesu FT-209
Crystals for 2 meter ham rigs:
Does anyone have an older two meter ham rig and need crystals?
Maybe I can help. I have some 2 meter crystals available -- both
transmit and receive. Most are in the 146 and 147 MHz band segments,
with very, very few in the 145 MHz segment, and none in the 144 MHz
segment. These are for ham rigs only, and not commercial rigs.
These are all the small HC-25 crystals, like are used in most of the
solid state 2 meter mobiles and HTs. Please e-mail the operating
frequency you need. I have them listed by operating frequency and rig,
and not by actual xtal frequency. Send the frequencies you need
(transmit or receive), and the rig that you have, and I will see if
I can help. I have cross references for the various rigs, so I will
know what you need if you give the rig. Crystals are $6 each.
I also have many other accessories available such as many
different types of microphones, HTs, HF, VHF and UHF rigs,
HF and VHF/UHF antennas, etc.
Just too many to list here. Please e-mail your requests.
Prices do not include shipping from Florida.
Thanks.
Ken, W8EK
Ken Simpson
E-mail to W8EK@FLHam.net or W8EK@arrl.net
Voice Phone (352) 732-8400
Notice: Due to a high number of swapmeet listings, I have
been asked by QRZ to provide the following notification:
My swapmeet sales on QRZ are not-for-profit. As a service to
my friends and acquaintances, I help them and/or their survivors
dispose of equipment that is no longer needed. Because I realize
the difficulty relatives have disposing of equipment after one
becomes a silent key, I have decided to "thin the herd" of much
of my own 40+ year accumulation of equipment. This is not a
business venture for me, and I am not in the amateur radio
business.
W8EK@FLHam.net / W8EK@arrl.net
Wow, lots of good stuff. And I think you win for the longest classified ad on QRZ!
