ad: Flexradio-1
Results 1 to 1 of 1
Thread: BARRETT 912 3-wire terminated folded dipole antenna
    NORTH AUGUSTA , SC .29860
    Thumbs up BARRETT 912 3-wire terminated folded dipole antenna
    BC91200 150 multi wire broadband dipole
    Frequency range 2 to 30 MHz
    Length insulator to insulator 27 metres 88 ' and 6.99 "
    Width 1.3 metres 4 ' and 3.18 "
    Power handling 150 W CW 250 W SSB
    The Barrett 912 series of broadband base station antennas are designed for use in either an inverted "V" configuration, using a single mast, or a standard dipole configuration, between two masts.
    In the inverted "V" configuration the 912 provides a more omni directional radiation pattern. All broadband antennas in the series are designed to provide optimum performance over a wide HF spectrum, without the need for antenna tuners.
    Using high quality stainless steel and glass reinforced composites the 912 series of broadband antennas are lightweight and corrosion resistant, but are able to withstand wind speeds in excess of 200 km/h.
    The antennas are supplied complete with an inverted "V" mounting harness, 30 metres of coaxial cable and high quality waterproof connectors.
    http://www.barrettcommunications.com...nas/index.html
    http://www.barrettcommunications.com...ole/index.html
    This antenna works great 160-6 meters with 100W & 200W If you want Just one antenna that does it all this is the way to go. 92' total length.
    E-mail John Rosica at Barrett USA john.rosica@barrettusa.com
    [FONT=Impact][SIZE=4][I]RICK[/I][/SIZE][/FONT]
    [FONT=Impact][SIZE=4][I]73 ![/I][/SIZE][/FONT]
