ad: dxsoft
Results 1 to 9 of 9
Thread: HRD LOG & The time
    Default HRD LOG & The time
    I keep having a problem with the clock in HRD log it keeps logging a diffrent time then what it is any ideas how to fix this?
    Steve Baker Sr. KB9HGI
    Echolink Node# 376163
    KB9HGI-L 147.555 T 103.5
    KB9HGI's Ham Shack:
    http://www.qsl.net/kb9hgi
    Iowa
    go to options,times..select start,end,UTC..all the settings are there
    Scott KB0NAZ
    I just brought up HRD program clicked on options and I don't see Time.
    I just worked a station on 12 meters at 19:17 UTC in my log it puts 13:17 which is 1:17 my local time.
    I will go dig around some more.
    KB9HGI's Ham Shack:
    Sep 2006
    Steve,
    Which version of HRD are you using, 4 or 5?
    Not Socialism or Communism.
    Iowa
    Quote Originally Posted by KB9HGI View Post
    in version5 in ALE ( Add Log Entry) options at the top,time is second..don't know about V4
    I have version 5 I think i have it now i was looking in the wrong places, Thanks KB0NAZ
    KB9HGI's Ham Shack:
    Jun 2008
    Marietta, GA
    It's kind of strange, but when you are logging a contact, it displays the time UTC. Then if you double-click on the contact to edit it or something, it displays your local time, although it still shows the correct time in UTC when you "close" the contact. Same for the date. I don't know why it does that; I have version 5.
    73, Frances / AJ4JQ
    Isaiah 26:3-4 "You keep him in perfect peace whose mind is stayed on you, because he trusts in you. Trust in the Lord forever, for the Lord God is an everlasting rock."
    Iowa
    that got me for awhile too.... glad you got it working now
    Scott KB0NAZ
    Nov 2009
    Missouri
    Places to change the time in HRD to UTC (I am running the most recent version):
    1. On the main HRD Screen, you can click on the time and set it to UTC, you may have the time on the left and right also.
    2. In the logbook, click on "More" and choose "Appearance" then select the "Logbook Window" tab and select UTC.
    3. In the logbook, in the ALE (Add Logbook Entry) under Options, select "Times" from the dropdown menu and select UTC.
    4. If you have the clock displayed in the logbook at the top, you can right click it and select UTC.
    5. In DM780, go to Options, then to Clock, and select UTC.
    6. In DM780, go to Options, then to logbook and click the "Appearance" tab and select UTC.
    Off the top of my head, these are some of the places to set the time to UTC. I'll try tro think of some more later. I don't have the problem of it changing the date or time when updating an entry, (at least yet).
    Jon
