Icom 720a help
Hi I own a ic720a and now have a problem the surge supresor a dsa301L is broken any ideas wher i can get hold of one in th UK or if I could replace with similar component ?
any help will be great.....
73's all
stuart
would a mov rated at 500vac with selinium cell do the job?
cheers
stu
you should be able to get that through ICOM.
Sue
AF6LJ
I don't have the IC-720A schematic handy but is this the device that's wired in across the antenna connection?
yes its from coax to ground on chasis with a 33k resistor
thanks for replys
cheers
stu
You don't even need it. The rig should work just fine with it removed.
It's really a lightning transient suppressor. An MOV won't do this job, it has too much capacitance.
If you have an external lightning arrestor that breaks down properly, this device is superfluous.
Thanks for all help but I have now tracked down the part direct from Icom UK should be with me in the morning..
73's all
stuart
