How to use MFJ Antenna analyzer
I'm wondering if:
1. Anyone know how to use the antenna analyzer to measure the resistance (at 1.8 mhz) of a choke balun I constructed?
1. Anyone know of any sites that discuss how to use the analyzer? I've already looked at MFJ's posts on YouTube - these are great, but I'm sure hams have posted their own tips.
Which analyzer do you have? MFJ has made at least six different models.
Resistance?? Do you mean impedance?
 Originally Posted by WA2SQQ
I'm wondering if:
I used a network analyzer to measure a ferrite bead choke on a 1' piece of coax that I made.
Resistance measured zero.
Impedance measured ~ 1000 ohms from 3 to 28 MHz peaking around 10k ohms at 14 MHz.
fp
ACØFP
Do you not have the manual for the analyzer? The manual for the 259 is here: http://www.utm.edu/staff/leeb/MFJ-259.pdf
See page 12 for testing baluns.
I'm wondering if:
As noted by someone else, your objective is to measure the impedance, it is a complex quantity with resistance and reactance.
Join both wires at the input and at the output of the balun, and connect them between the analyser's ground connection and centre pin. There should be nothing else connected to the balun.
Now put in in impedance measuring mode, and write down / plot the impedance components over a range of frequencies. It is most likely that the reactance component at the low frequency is positive, but at much higher frequencies, it will probably become negative.
The impedance of a good common mode choke may be higher than you can measure with the MFJ259B for example.
Owen
If those are Fair-Rite ferrites then go to their web site and look up the impedance curves over the frequencies you want. Im not aware of any MFJ instrument that will be satisfactory.
Carl
The MFJ-259B is limited to measuring impedances less than ~650 ohms. If your choke balun is a 1:1, just short the input wires together and the output wires together, and measure the impedance. If it is less than 650 ohms, the MFJ-259B should yield a reasonable result. Hopefully, the impedance will be too high for the MFJ-259B to measure.
73, Cecil, www.w5dxp.com
fp
Do you mean that the DC resistance measured zero? It would be very unusual if a choke had zero resistance from 3 to 28MHz.
Steve G3TXQ
Carl
Unless I'm mistaken, all you'll find of relevance on the Fair-Rite web site is curves of μ' and μ'' vs frequency. You need more information than that to predict the choking impedance.
Steve G3TXQ
If the Z is above the MFJ's range, you can extend the measurement range by using other known passive devices such as a resistor across the terminals in parallel with the unkown part under test. With the impedance now within range of the MFJ unit, you can mathematically remove the known resistance revealing the higher unknown impedance of the part in question. My homebrewed impedance measuring instruments and some of my ancient commercial instruments are limited in the same way so if I can do it, anyone can Plus it is a good exercise in learning AC circuit theory For example, my old noise bridge (applicable for a Palomar as well) can only reach an Rp (parallel equivalent resistance) of 250 Ohms so I would place a 330 Ohm low reactance resistance in parallel to the unknown and null the bridge under this condition and then remove the 330 ohms mathematically. If any one would like to work thru an example, let me know and I'll go thru it step by step. The useful formulas here are the series to parallel and parallel to series conversions. I programmed these into my HP calc and have also loaded everything into a spreadsheet. 73, Pete
