incoming or out going contact ?
I noticed in my log book, I have no way of telling contacts I sent, or received.
I see it tells me at the bottom, 3 sent, 4 rec'd, but it does not indicate which ones
are which..
I hate to complain without providing a suggestion for correction or improvement,
so, how about the carrot at the beginning of the date to determine if this was sent out, or came in. > for out going, and < for incoming.
so :
2010-08-29 22:01:00 W6TUG 70cm 41.625 FM DM13na MYRON M BALCHIN, SR
would be :
>2010-08-29 22:01:00 W6TUG 70cm 441.625 FM DM13na MYRON M BALCHIN, SR
because I initiated or originated the contact to my uncle.
just an idea.
Dan. kb7uxe
Dan, I'm not sure what you are looking at. My log has arrows that show at a glance whether a contact is incoming or outgoing. Make sure you select the logbook button on the screen that shows up when you look up your call. You'll see the arrows then.
..........Bob
