Results 1 to 3 of 3
Thread: Icom IC-7000 transceiver display problems
    Default Icom IC-7000 transceiver display problems
    Does any one have problems with the display on IC-7000? Some times, mostly when turned on, the display is lost and there are nothing on it.
    Jan 2002
    harms way
    Hi there!
    I've no experience with the 7k, but you may find out something here:
    http://groups.yahoo.com/group/ic7000/
    Apr 2002
    Rochester, MN
    If this is happening when you transmit, it could be RF getting into the control head.
    Usually, this will be cured if you have used the small (3mm) screw to connect the shield of the separation cable to the radio.
