URGENT: Argent Data T2-301
Anyone use one? I need help getting the radio side programmed using the serial port commands to change the frequency.
I have the programming cable pined out and wire correctly. But the serial port programs are not showing the radio connected. Even though I am able to program the tracker portion of the radio with no problems with the same connection configuration.
I will have an auto email notification on this post so hopefully if you reply I can get back with you quickly.
Also you can PM me I check these things quite often each day.
73s and thanks in advanced.
ND5ND
