ad: giga-rw
Results 1 to 10 of 11
Thread: Kenwood TS-440SAT IC-10 Upgrade Gone Wrong
    AC5ZU Guest
    Default Kenwood TS-440SAT IC-10 Upgrade Gone Wrong
    I intended to modify my old 440SAT with a couple of IC chips (IC-10 Interface Kit) that would enable computer rig control capability via ACC1. Got the chips in the mail, read the instructions in the owners manual, and start pulling the covers and face apart to get access to the logic board behind the control panel. Made sure I was grounded, then popped the chips in, closed everything back up (being careful not to pinch any of the myriad wire bundles in there) and powered up.
    I was greeted with no receiver noise or control capability and a VFO display of all '8s'.
    Opened everything back up and reinspected my work. Saw that one of the chips (the CMOS divider) I thought I had put in was only half in. One entire row of pins on one side of the chip missed the IC socket. I pulled the chip back out and reseated it.
    Before closing up this time, I powered the rig up and got a new but equally disturbing result. Still no receiver noise, but now the VFO display is garbled and strobing rapidly.
    Maybe the chips were bad? I pulled them out; no change.
    So has anyone seen this in a 440? Is there some simple error I made when I opened up the unit? Is it worth spending the money to get it fixed? Does Kenwood even still repair these old rigs?
    Any suggestions would be appreciated.
    Dennis Wofford
    AC5ZU
    Dennis -
    These 2 integrated circuits: IC54 - uPD8251AC (NEC) and IC55 - TC4040BP (Toshiba)
    provide a serial connection to the uProcessor used in the TS-440SAT.
    Your TS-440S Operator's Manual provide the proper instructions on page 29 -- 6-3 Interface TC Kit IC-10 Installation
    Kenwood stopped providing service support for this radio when some
    component parts (from their suppliers) became unavailable.
    BTW, this radio and its technology components are almost 30 years old !
    The TS-440S is a great starter radio -- I have one here that I cleaned and updated in 2005 from a silent key estate. I have the service and operating manuals (that I acquired when I worked on this radio in 2005) -- so it was fairly easy for me to look this up.
    I saw that one of the chips (the CMOS divider) I thought I had put in was only half in. One entire row of pins on one side of the chip missed the IC socket.
    That mistake was on radio's uProcessor control board (ugh) ... Patience is a required skill with radio repairs!
    Contact Clif Holland, KA5IPF at Avvid in Mabank, TX, who specializes in Kenwood radios of this vintage,
    he may be able to help you with your radio.
    http://www.avvid.com/
    There are Yahoo groups dedicated to the TS-440S and Amateur Repairs,
    I have contributed to both (files section).
    Feb 2002
    Ripon, England
    Bin the 4040 and try again, BTW I used an 82c51 and that worked fine.
    Feb 2010
    Highland,IN
    I also have a 440 it's my starter radio and I love it. I just wonder do they make a DSP add on for it?
    AC5ZU Guest
    Default Thanks!
    Well, after chatting with one of the local hams about my situation, he suggested I do a MPU (main processor) reset. Found the procedure in the manual. It was brain dead easy; hold down A=B function button while turning the rig on. Shazam! Everything is working beautifully. Got the serial to USB interface working through ACC1 and the IC-10 chips are now letting me get full rig control (okay, as much as the 440S will do, anyway) through Ham Radio Deluxe.
    Although I found this solution outside this forum, it's always good to have a repository of such knowledge that QRZ offers. It's saved my bacon in the past on other areas, for sure.
    Thanks for everyone's willingness to help!
    Dennis
    AC5ZU
    Dennis -
    Glad to hear that you resolved your issue. I thought you already preformed the uProcessor reset ? -- glad that the uProcessor reset did the trick (other options were ugly).
    BTW, while you had the radio open did you check the lithium coin cell battery for leakage? Even though mine worked, it had started to leak -- which required clean-up of the electrolyte paste (acid)
    Not as an Internal option (DSP chips for audio and radio usage came about 10 years AFTER the TS-440 was designed in late 1970s/early 1980s).
    You could purchase an external audio based DSP, if you desired.
    Radios with Intermediate Frequency (IF) based DSP designs have only been available since ~ 2000 (e.g. Icom 756Pro).
    Feb 2010
    Highland,IN
    Dennis -
    That's what I thought. I had a CB in the 90's that had DSP. I'll have to check the TS-440 Yahoo group for what the best external option might be.
    If the MPU reset didn't work, I would have suggested replacing the 4040 chip. At least THAT is an inexpensive COMS logic chip. (The 8251 chip is obsolete and is getting difficult to find.) Plugging the chip in with half the pins improperly terminated and connected could have damaged the chip; apparently it didn't. But it's something to double check every time.
    May 2009
    CM97cg
    Quote Originally Posted by AC5ZU View Post
    The last time I read a set of instructions on the IC-10 install, It specifically said to do a reset after installing the chips.
    "Keep the Amateur in Amateur Radio. Keep the professionals and Part 90 out." Ed Brooks, W5HTW (SK)
    If you can't make fun of yourself, go sit in the truck - W5WPL
    Jun 2010
    Norcross GA, USA
    In my case, the Divider and the UART chips went in smoothly enough, but there was no RXD / TXD to or from the radio. That was confirmed with an O'scope. Probing around, I determined that the chip designed to work in conjunction with the crystal wasn't providing a clock. No clock, no UART operation. That one chip was soldered in, so either the rig was manufactured with a bad part, or something caused it to go bad during it's use prior to coming into my care.
    Having the proper equipment to diagnose an issue is important. But you've got to have the proper tools to fix the problem you find too. In my case, desoldering tool, angle cutters, a good kelly clamp, magnifying glass and strong lighting. Specially the last two.
    I strongly agree, this is a great starter radio... I'm learning a lot with it and having a good deal of fun.
