ad: seapac-1
Results 1 to 10 of 22
Thread: Ham Radio Gadget updated N0NBH solar data tool
    Dec 2007
    Seattle WA
    Default Ham Radio Gadget updated N0NBH solar data tool
    A significance update to the windows 7 ham radio gadget
    now supports all the new solar data available on n0nbh as well as more formats of the data, lots of major bug fixes as well as more options for the gadget settings.
    http://gallery.live.com/LiveItemDeta...e-0993d61b3bca
    ___________
    Seattle,WA
    Great post and thanks for the link!!
    Feb 2002
    Belfast, Ireland
    Unfortunately it won't work in Windows 7 64 bit
    73 de Daithi
    Apr 2007
    Levittown, PA
    Quote Originally Posted by GI7OMY View Post
    Sure it does. I just loaded it up and it works fine
    Tom - AB3FL
    I may not know CW, but I can operate a boatanchor!
    cant open files on mine
    Dec 2007
    Seattle WA
    yea it was developed on a 64b machine so no idea there... the way a gadget works the processor has nothing to do with the compile so its platform independent, the only thing that you would want is windows 7 because vista limits the room for a docked gadget the data in the gadget is larger then the vista allotted room, windows 7 has no docking so its not an issue
    when you say cant open the files... it should be called HamRadio.gadget when you double click on it windows will know what the file is and ask if you want to install it... where do you get a error? in the download or the install...
    might also recommend using IE to download the file
    ___________
    Seattle,WA
    Apr 2009
    Houston, TX
    Works fine on mine too.
    Smile
    Seriously SLICK!
    Works here fine on Windows 7 64 bit.
    Jim
    W4YXU
    Aug 2002
    DM42of
    Thanks, great work.
    Works great on Windows 7 64-bit for me. I did have to use IE to download it rather than Firefox though.
    Feb 2002
    Belfast, Ireland
    All I get on trying to install (either via IE8, Firefox or manually after download is 'Unspecified Error'
    OS is Windows 7 Ultimate
    Edit - I also tried with A/V and spyware blocker off - same thing
    73 de Daithi
