Results 1 to 6 of 6
Thread: ADIF Download - starting it was confusing
    Aug 2007
    Waldwick, NJ
    Default ADIF Download - starting it was confusing
    I saw the post in the other forum that ADIF downloads where now available. I went to the options tab on the left side of the logbook page and download was grayed out. So I clicked back and forth a bit and it was still grayed out. Just for the heck of it I pressed the refresh button and lo and behold, it queued a request up. Completely non-intuitive to me. Maybe labeled Request and the first button and Download is the 2nd button?
    It is 3 mins later and I'm still waiting. I have 21 entries in my logbook. How long might it take?
    Aug 2007
    Waldwick, NJ
    I was waiting on that page and it never refreshed, even switching between tabs which obviously isn't refreshing the page. I then clicked on the Logbook button in the top toolbar and with it refreshed, the Options tab now shows available.
    Clicking download in Chrome,FF or IE causes the ADIF file to be displayed in the browser window. Switching to dlb version it downloads the file. Both the dlb and non-dlb versions of the page show Test version 1.13
    Looking at the ADIF, it only contains 14 records. My current logbook on the site shows 21 total records, 16 confirmed. Looks like the ADIF contains only the records which I've loaded, not ones others have loaded and I have confirmed. Does that make sense?
    Loading into HRD via the ADIF import, the dates all show as 1/1/2000 but the times seem accurate.
    In a serial # exchange, the sent serial # isn't populated in HRD but the received serial # is.
    From what I can tell, the rest of the first record imported I looked at seemed good. It could be a HRD specific mapping (out of my control) with some of the other fields but I will look deeper. Will also try ADIF Master
    Aug 2007
    Waldwick, NJ
    Looking in ADIF Master I see the following:
    No QSO_DATE / QSO_DATE_OFF in the generated ADIF.
    The file has SRX and SRX_STRING. You are populating one with the received contest exchange and the other with the sent contest exchange. STX/STX_STRING should contain the sent exchange.
    The rest seems ok in ADIF Master.
    Aug 2007
    Waldwick, NJ
    The Note/Comment in the Logbook isn't being exported to the Comment field in the ADIF.
    Jun 1992
    Phoenix, AZ
    Default UPDATE
    K2DSL - I have addressed several of your reports.
    Both versions now present a Download box instead of going to the screen.
    QSO_DATE and QSO_DATE_OFF now included.
    SRX now changed to STX
    Comments now exported to the NOTES field, as well as the COMMENT field.
    Fred Lloyd, AA7BQ
    Publisher, QRZ.COM
    aa7bq@qrz.com
    Need QRZ Help? Click Here
    Aug 2007
    Waldwick, NJ
    Consumed the latest QRZ ADIF into HRD. The import in HRD indicates that QSO_DATE_OFF is not supported by ADIF but that isn't something on your end.
    Some records have a lower case x in the Contest field when viewing via ADIF Master.
    The sent/received contest exchanges still seem to be incorrect. STX & STX_STRING are the only 2 fields in the ADIF and from your last post it should be SRX & STX.
    I also don't see any NOTES coming through.
    I'm sure the file is the latest because the dates are now coming through.
