ad: N3WG-1
Results 1 to 4 of 4
Thread: Wiring up a Motorola Mic to a Kenwood TS430
    Nov 2009
    Leighton, AL (EM64fq)
    Smile Wiring up a Motorola Mic to a Kenwood TS430
    I have a Motorola mic that was given to me that I'd like to try to wire up and use on a Kenwood TS-430S HF rig... was wondering what the wiring setup would be...
    Number on bottom of mic: TMN1004A-1
    Thanks!!
    KJ4QMP
    May 2009
    CM97cg
    I think you would have better luck asking here: http://batboard.batlabs.com/index.php
    If the mic came off of a newer motorola rig. I dont think it would be possible without building an interface. IIRC, the newer motorola mics actually need 12v power for the circuitry inside them.
    "[I]Keep the Amateur in Amateur Radio. Keep the professionals and Part 90 out[/I]." Ed Brooks, W5HTW (SK)
    [B][SIZE=3]If you can't make fun of yourself, go sit in the truck :cool: - W5WPL[/SIZE][/B]
    Mar 2001
    North Olmsted, Ohio
    Default Motorola Mic
    If you decide not to use that Motorola base mic, let me know. I'll buy it from you. I have a Motorola Spectra that it would work with very well. I am ok on roadrunner.com. My call at etc. 73! de
    [FONT=Arial Black][SIZE=4][SIZE=3][FONT=Garamond]John, WA8LGM
    Hey!! Why am I in this handcart and where am I going? :mad::mad:
    [/FONT][/SIZE][/SIZE][/FONT]
    Most MOTO mikes have a transistor preamp inside, and require a bias voltage -- about 6 volts give or take a lot -- to work.
    The output is quite high as well, far in excess of what the 430 needs.
    You could build a box with a DC feed and attenuator, but that is more stuff you wouldn't need if you would find a medium Z dynamic mic in the first place.
    The MOTO mike is designed to replace a carbon microphone in operation . . .
    Gary WA7KKP
