Antennas - VHF and UHF, Monitor antenna, Mobile antennas, rubber ducks, & connectors
Antennas and antenna related items for sale:
Hustler MOS Monitor Antenna:
The Hustler MOS monitor antenna is for use on indoor scanners.
It features a suction cup to hold it to the top of the table.
A Motorola type connector can be moved up and down the antenna
so that it is just the right height to plug directly in to
your scanner.
Basically, this antenna will attach to the table behind your
desktop scanner, out of the way, but will provide a significant
amount of gain over the internal antenna.
This particular antenna works fine, and looks very close to new.
$20
Larsen VHF and UHF Mobile Antennas:
Antennas are used, but in very good condition.
Larsen NLA-150, 2 meter antenna, for Larsen NLA mount
Has about 3 db gain on 2 m; includes whip. $16
As above, but coil only, without whip. $10
Larsen NLA-450 coil and "stacked" whip for 440 MHz
Fits the Larsen NLA mount, and has about 5 db gain on
the 70 cm band. Stacked whip is included. $12
Larsen NLA-Q
Fits the Larsen NLA mount, but is a quarter wave antenna.
Can be cut for 2 m, 220 MHz, or 440 MHz. $9
Larsen Q Quarter Wave Antenna
Fits a 5/16 inch stud, such as the Larsen LM mount,
and others. It can be cut for 2 meters, 220 MHz, or
450 MHz bands. $8
Trunk Lip Mount with 5/16 inch stud
Ideal for use with the "Q" above, or any other antenna
that requires a 5/16 inch stud. Very nice for $18.
Avanti "On Glass" antenna for 440 MHz:
This antenna was made by Avanti to mount on a windshield,
or other glass. It does not require a ground plane, as
it is a 1/2 wave antenna, rated to have 3 db gain. It is
ideal for places where a ground plane is not available,
such as a boat or motor home, in addition to cars. A
special tuning box is included to match to your particular
situation.
Avanti Antenna for 440 MHz
Still in its original tube, unopened. $33
Hustler HF mobile resonators:
All work fine and are in good cosmetic condition.
"Super" high power resonators (good for 2 KW PEP):
80 meter RM-80 S
can be cut for CW or phone, and also used on a 4BTV
Vertical to give 80/75 meter coverage
(basically make it into a 5BTV) $38
Rubber Duck antennas for your HT.
All are for 2 meters, are in good condition,
and are $10 each, unless stated otherwise.
BNC Regular length, 6 1/2 inches long
BNC - Original from Kenwood TH-215, 5 inches long
Alinco Stubby w/BNC Connector, 4.6 inches long
5/16 inch threaded, like used by Motorola and others
Stubby - 4 inches long
Type F connector - 6.5 inches long
PL-259 connector - 6.5 inches long
HyGain 275, still in original packaging
PL-259 connector - Stubby - 4.6 inches long
Centurion, still in original package
Special for Kenwood TH-21 HT threaded connector
Kenwood RA-6 regular, 6.6 inches long - $15
BNC Stubby for 440 MHz, 3 inches long
Low Pass TVI Filters:
A low pass TVI filter is added to the transmitter (inserted
in the coax line after the transmitter or transceiver) to
reduce harmonic interference.
Bencher YA-1, high power, low pass TVI filter
If you need a more heavy duty filter for the output of
your amplifier, this one is ideal. It will take full legal
power plus, and has at least 80 db signal attenuation at
TV channel 2.
It is also in a very sturdy metal case with SO-239 connectors
on each end, and is a 50 ohm filter.
This one works great, and looks close to new. Someone added
some felt to the bottom, so that it protects better. It is in its
original box, with paper work. Bencher currently sells these
for about $90. This one is only $65.
B & W FL-10/1500 (Also known as model 425) low pass filter
B & W TVI filter, 50 ohm. It cuts off just above 10 meters,
and will handle 1500 Watts. SO-239 connector on each
end. This is the latest model B & W filter. It is in very nice
condition; it looks very close to new. With paper work $40.
Drake TV-5200-LP
This is the more modern version of the Drake TV-1000 Low Pass
Filter. This is the filter that may also be used on the low
end of six meters, as well as HF. It is good for 1000 Watts
average below 30 MHz, and about 200 W up to 52 MHz. It works
fine, and is in very nice shape. $35
Drake TV-3300-LP Low Pass Filter
This is a modern low pass filter to go between your transmitter
and antenna, and has been optimized to have more attenuation
in the 40 MHz region, where many TVs have their IF. It is good
for 1000 Watts "average" according to the manual, and has
over 80 db attenuation at 41 MHz. This one looks great, and
includes the paper work. $30
ParaDynamics PDC-5 Wattmeter
This unit has a wattmeter with scales of 100 W, 10 W, and
1 W. It has an SWR Bridge built in, with an antenna tuner.
It was obviously made for 11 meter use, but it works well
on other frequencies. The tuner portion works fine on 10 m,
12 m, and 15 m. The wattmeter seems accurate from 20 meters
thru 10 meters.
It is physically small (only 5 X 3 X 1), so would be ideal
for portable use.
The wattmeter and antenna tuner portion work fine, however,
the SWR portion of this unit is inoperative. It looks fine. $12
Coax Cable with Type "N" Connectors:
This cable is made of RG-8 coax and is about 6 feet long.
It has a male type "N" connector on each end. $15
Coax connectors and adapters:
Prices are per connector. Several of each are available.
These are NOS (have not been used).
BNC male for coax cable
standard type - $2
crimp on type - $3
Chassis mount BNC female
square mount (uses 4 screws) - $3
screw in type - $3
BNC 90 degree - female to male - $3
BNC "T" - two female and one male - $3
Antenna adapter to fit the BNC connector on the HT
and provide an SO-239 connector that will permit
a PL-259 to be attached. (BNC male to UHF female) $5
UHF Male (PL-259) to BNC female (opposite of above) $5
UHF double female "Barrel connector" (two SO-239 together) $3
UHF "T" connector with two female (SO-239) and one male
(PL-259) connection - $5
Antenna adapter for Kenwood TH-21/31/41 HTs
Adapts the antenna connector found on these HTs to a
standard PL-259 connector. $6
Prices do not include shipping from Florida.
Thanks.
Ken, W8EK
Ken Simpson
E-mail to W8EK@FLHam.net or W8EK@arrl.net
Voice Phone (352) 732-8400
Notice: Due to a high number of swapmeet listings, I have
been asked by QRZ to provide the following notification:
My swapmeet sales on QRZ are not-for-profit. As a service to
my friends and acquaintances, I help them and/or their survivors
dispose of equipment that is no longer needed. Because I realize
the difficulty relatives have disposing of equipment after one
becomes a silent key, I have decided to "thin the herd" of much
of my own 40+ year accumulation of equipment. This is not a
business venture for me, and I am not in the amateur radio
business.
W8EK@FLHam.net / W8EK@arrl.net
