ad: giga-rw
Results 1 to 8 of 8
Thread: HP will not scan but prints fine.
    Jul 2001
    Poteau, Okla
    Default HP will not scan but prints fine.
    I have a HP photosmart C4180 all In One printer – Scanner. It prints just fine. But it will not scan. The light bar does not light nor does it make a pass. It just sits there. The little flop up screen says it is scanning but nothing happens. I have re installed the software and it says everything is fine. But it won’t scan. Any ideas?
    I have two hard drives one has XP the other Windows 7 64 bit.
    http://www.ka5row.com Jesus is God
    Matthew 24:27 For as the lightning cometh out of the east, and shineth even unto the west; so shall also the coming of the Son of man be.
  2. Default
    Try this info from the HP site:
    http://h10025.www1.hp.com/ewfrf/wc/d...41647&lang=en#
    Might apply to Windows 7 too.
    Pete, wa2cwa
    Aug 2004
    Des Moines, IA
    At work we have found that if you don't load HP USB printer drivers with admin privies, and before you ever plug the device into the computer, some or all of the functionality of the device won't be installed.
    CW is a manually controlled, message asynchronous, simplex chat mode used without FEC.
    "The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." -- Thomas Jefferson
    DX Code of Conduct
    Registered Linux User #307249
    ACØH
    SPAR
    ARRL
    SKCC #215
    NAQCC #3441
    FISTS #11993
    Sep 2009
    Deer Park, Texas
    Talking Try the Paint program from Accessories, Programs
    Try the following: From the Start Menu ( flag logo in left lower corner ), pick All Programs, Accessories, and Paint. Once the program is open, click on the File menu in the upper left corner. The choice of "from scanner or camera" then becomes obvious. HP posted this to users of the Printer-Scanner-Copier model 1610 who had registered their product on the company website and maintained the same e-mail address for their database. You could then send a small donation to QRZ for bringing this message to you, after I stored it for you on the system. You are welcome. 73 de KB0MNM- Jon
    Quote Originally Posted by KA5ROW View Post
    To send Internet e-mail to both me and my YL Karen use:
    jklivingston10@att.net
    for us. The QRZ private mail system also
    forwards it. 73 de KB0MNM- Jon
    Jan 2005
    Canada
    Quote Originally Posted by AC0H View Post
    Bingo.
    Many people still make this mistake. They're so anxious to get the printer working that they connect it first, and then install the software.
    USB devices should ALWAYS be done in reverse.
    1. Install software
    2. Connect when prompted to (or after software install is done)
    You will need to update the driver for your USB.
    Or... to make this even easier... uninstall your printer; disconnect your printer; reboot Windows; then do it the right way as above.
    HP provides both a single device installation package and they also have a "blanket" installation package which provides the installation for all of their accessories including printers, webcams, digital cameras, etc. I learned in a hurry just to download the entire package and be done with it.
    Their "blanket" package also recognizes a lot of the other accessories made by others as well as HP products. I have HP 4200 series and HP 4400 series printers/scanners and those installed without any problems using the "blanket" package.
    Jan 2010
    McDonough, GA
    Thumbs up Scan through the Software
    The scan function on HP All-In-One copiers is strange. Sometimes it works from the copier button, but many times you have to start the scan from the software only. I would remove the software and re-install it.
    Glenn
    Jul 2001
    Poteau, Okla
    I gave up tried everything. I will connect it to a different PC in the house. I may get the HP 6500, so I can scan with mine. Thanks for the help.
