HP will not scan but prints fine.
I have a HP photosmart C4180 all In One printer – Scanner. It prints just fine. But it will not scan. The light bar does not light nor does it make a pass. It just sits there. The little flop up screen says it is scanning but nothing happens. I have re installed the software and it says everything is fine. But it won’t scan. Any ideas?
I have two hard drives one has XP the other Windows 7 64 bit.
http://www.ka5row.com Jesus is God
Matthew 24:27 For as the lightning cometh out of the east, and shineth even unto the west; so shall also the coming of the Son of man be.
Try this info from the HP site:
http://h10025.www1.hp.com/ewfrf/wc/d...41647&lang=en#
Might apply to Windows 7 too.
Pete, wa2cwa
At work we have found that if you don't load HP USB printer drivers with admin privies, and before you ever plug the device into the computer, some or all of the functionality of the device won't be installed.
DX Code of Conduct
Registered Linux User #307249
ACØH
SPAR
ARRL
SKCC #215
NAQCC #3441
FISTS #11993
Try the Paint program from Accessories, Programs
To send Internet e-mail to both me and my YL Karen use:
jklivingston10@att.net
for us. The QRZ private mail system also
forwards it. 73 de KB0MNM- Jon
Bingo.
Many people still make this mistake. They're so anxious to get the printer working that they connect it first, and then install the software.
USB devices should ALWAYS be done in reverse.
- Install software
- Connect when prompted to (or after software install is done)
You will need to update the driver for your USB.
Or... to make this even easier... uninstall your printer; disconnect your printer; reboot Windows; then do it the right way as above.
HP provides both a single device installation package and they also have a "blanket" installation package which provides the installation for all of their accessories including printers, webcams, digital cameras, etc. I learned in a hurry just to download the entire package and be done with it.
Their "blanket" package also recognizes a lot of the other accessories made by others as well as HP products. I have HP 4200 series and HP 4400 series printers/scanners and those installed without any problems using the "blanket" package.
Scan through the Software
The scan function on HP All-In-One copiers is strange. Sometimes it works from the copier button, but many times you have to start the scan from the software only. I would remove the software and re-install it.
Glenn
I gave up tried everything. I will connect it to a different PC in the house. I may get the HP 6500, so I can scan with mine. Thanks for the help.
