ad: giga-ldg
Results 1 to 9 of 9
Thread: windows xp problem
    Default windows xp problem
    Hi everyone hope some one out there can help me .
    when i switch on computer running windows xp pro
    i get two options to load it
    both say on the startup screen
    select the operating system
    then displayed is
    m/soft windows xp pro
    and underneath
    as there is nothing in the second one at all, i need to remove it from the start up.
    Regards
    Graham .
    Exclamation
    Hi, Graham
    You really should have posted this under the computer forum
    http://forums.qrz.com/forumdisplay.php?f=29
    it could be a number of things like an old partition or a parchel install/set up
    one way or the other, you need to edit the boot loader and delete the old or unused path. but you need to find out witch one is what first.
    EG goto the start menu, find the C prompt or in the search box type in cmd
    then type in the following (only if you know what you are doing):
    bcdedit help
    make sure you know witch one is the working path and witch one is not, with that said, and please note,,
    editing the wrong path will stop the pc from booting to windows.
    73 good luck i am sure someone here will offer more advice but good luck.
    Never Be The First To Get Old
    Web Link:
    http://groups.yahoo.com/group/K4EEZ/
    Oct 2005
    ELBERTON GA.
    Been running linux too long to do anything other than suggest:
    Run linux
    "ANY SOCIETY THAT WOULD GIVE UP A LITTLE LIBERTY
    TO GAIN A LITTLE SECURITY DESERVE NEITHER
    AND WILL LOSE BOTH." -BENJAMIN FRANKLIN
    "WE'RE IN A WAR,DAMMIT!
    WE'RE GOING TO HAVE TO OFFEND SOMEBODY!" -JOHN ADAMS
    POLITICAL CORRECTNESS=CENSORSHIP
    Jan 2010
    Gilbert, AZ
    Yes, editing the boot.ini file using notepad will do this...
    Nov 2008
    Monroe, WA, US
    The easiest way is to just disable the menu. It's been a while since I've had to do this, but this should do the trick. I've attached a numbered screenshot to follow along with:
    1. Open Control Panel (Start->Control Panel)
    2. If it's not already, switch to classic view. In the picture I'm already in classic view, which is why it says category view.
    3. Open the System control panel
    4. Go to the Advanced tab
    5. Under Startup and Recovery, click Settings. This will open the Startup and Recovery dialog
    6. Uncheck "Time to display list of operating systems" checkbox
    7. Click OK in the Startup and Recovery dialog
    8. Click OK in the System Properties control panel
    That should do it!
    Quote Originally Posted by K4EEZ View Post
    Hi, Graham
    bcdedit help
    Hi and thank you for your help tried it but its still there sorry abt the wrong classification slapped wrists for that .
    i am going to try the other replys
    Regards
    Graham
    Hi tried your idea and yes worked first time thanks for the help
    some where down the line comp must have had xp put in twice but not installed fully the second time
    anyway its good to get it off the screen
    all the very best to you for your help
    Regards
    Graham
    Thumbs up
    Quote Originally Posted by G1UTS View Post
    start up.
    Regards
    Graham .
    Thank you all who replied problem now solved by using idea from W7BEC that worked first time .
    so to you W7BEC thank you very much
    Regards
    Graham
    Mar 2008
    Excelsior MN.
    See below for my answer.
    Hi, Graham
    He did put it in the right place
    bcdedit help
    This is a Vista or W7 tool not an XP tool.
    KD0DKI Sam
    "Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
