ad: Waters-2
Results 1 to 7 of 7
Thread: Need a vintage CT7001 clock chip
    Sep 2007
    Castaic Ca
    Default Need a vintage CT7001 clock chip
    If anyone has one for sale or trade or knows where I can get one, please reply to ruteng1 @ att . net
    Thanks, Rudy
    That is an old Fairchild / Cal-Tex part number (circa 1978).
    IF you find old Radio Shack blister pack parts, look for part number: RS1756 -- that was the Cal-Tex clock IC.
    Here is an old Datasheet / Application note for this MOS/LSI Clock Calender
    http://www.electronballet.com/Datash...ock/CT7001.PDF
    Can you use the NTE2060/1 ??
    These do not have multiplexed outputs.
    W6OP Guest
    I have a Mostek MK50252N Radio Shack 276-1751 with data sheet. Is that close enough?
    Pete W6OP
    Quote Originally Posted by W6OP View Post
    Pete W6OP
    Not really. The two parts are vastly different and not interchangeable.. The only thing they have in common is that they are both Digital clock chips.
    May 2001
    Ivins, Utah
    Quote Originally Posted by WA6PEW View Post
    Thanks, Rudy
    I have one, sent you a message at your listed email.
    Ned
    W6OP Guest
    OK, didn't know if you were looking for a replacement for a bad one or just wanted to build a digital clock.
    Pete W6OP
    Sep 2007
    Castaic Ca
    Default thanks
    thank you all for you interest and suggestions. I do need the CT7001 only as it is replacing a blown one in an old clock I made back in the 70's
    Rudy
