ad: Rohn-1
Results 1 to 5 of 5
Thread: Kenwood TRC-80
    Default Kenwood TRC-80
    Hi wonder if anyone out there is good enough to help me out i purchased a TRC-80 by Kenwood and it has no backup battery it has been taken out !!!!
    and the manual i have for it on disk only mentions what it controls .
    so if possible i need to know what type of back up battery is required.
    the number on it
    the voltage
    must say this is the first time in all the years on QRZ.com i have needed your help this is a very fine site with lots to do on it and is a very well set up site.
    Thanking you all that respond .
    Take care
    Regards
    Graham
    Oct 2004
    SCUNTHOPRE, NORTH ENGLAND
    Hi,
    Not sure if there is anything in the service manual but i have shown a link to it below, incase you do not have it.
    http://www.zs6kmd.za.net/pdf/TK80_Service_Manual.pdf
    Looks like the kenwood part number is W09-0515-05
    A replacement part from mouser.com is http://gb.mouser.com/ProductDetail/S...V3pLFGtQ%3d%3d i got this information from here http://www.eham.net/forums/MobileHam/15341
    And finally an option in the uk maybe CR2430 , 3v 280mah http://www.dabs.com/products/sony-li...v-x1-4GMP.html
    I maybe be wrong but i followed the google trail ha ha ha
    Sam
    Default reply to sam
    Hi sam. thanks for the info just having a quick look lots of pages to go through so will take some time thanks for taking the time. the sites you gave me look good
    Many thanks
    Graham
    I purchased a TRC-80 by Kenwood and it has no backup battery.
    The battery has been taken out !!!!
    I do not believe that this specific Kenwood HF radio model sold in North American market.
    Sanyo CR2430-P1-2 Coin Cell Battery with Leads 270 mAh
    BTW, check with Mouser, but you may NOT be able to have that Sanyo battery shipped to UK.
    http://gb.mouser.com/catalog/640/2075.pdf
    Photo of TRC-80 radio
    http://www.ameradio.com/pop_up.html?...756&model=5486
    TK-80 (TRC-80) HF SSB Radiotelephone transceiver, SSB/CW/FSK 100W,
    AM 25W, 80 ch memory, large LCD display, 13.6 VDC, included Owner's Manual, DC cable, microphone, fuses.
    RX: 500 kHz to 30 MHz, TX: 1.8 MHz to 30 MHz, adjustable RF power output, clarifier, VOX,
    Data Mode, CW full and semi break-in, optional internal or external antenna tuner,
    optional selective call system.
    These radios usually used Lithium Coin Cells WITH Solder Tabs (that varied between models).
    Your UK Panasonic or Sanyo distributors or dealers should have the appropriate lithium cell.
    In the States (USA), if the specific lithium cell is no longer offered by Kenwood,
    we have hundreds of Batteries Plus retail outlets.
    They have the equipment in their stores to "spot weld" appropriate solder tabs to the cell.
    Panasonic lithium coin cells
    http://www.panasonic.ca/english/batt...coin_specs.asp
    Manuals
    http://www.user-manuals.com/advanced...3a56a673802822
    BTW, the Kenwood Appliance division also makes a TRC-80 Coffee Maker ...
    now that is an interesting combination!
    Default W9GB ref TRC-80
    Hi.
    thank you for the infomation. and all the links for various sites.
    i will have a look around at them.
    thnks for taking the time for putting so much info on whats available .
    Regards.
    G1UTS
