DB-224 for a mast for HF antennas
I am using a DB-224 mast to hold my antennas. For those who actually know what one is, Do you think it is strong enough to hold ? I cut the second part of the DB-224 mast and have a 4ft extension I could use to add a little more space between my Mosley CL-33 and the Cushcraft A3WS. I am getting a lot of interaction on 10M. All of the other bands are just fine, on the two antennas.
You can see the antennas with the mast without the extinction at my web page.
http://www.ka5row.com Jesus is God
Matthew 24:27 For as the lightning cometh out of the east, and shineth even unto the west; so shall also the coming of the Son of man be.
You should be OK with the larger antenna just above the top of the tower. Although the antennas are not as large as yours, I am using one section of a DB products antenna as the mast on my "short tower".
http://k9sth.com/uploads/Antennas_At_K9STH.pdf
DB Products used some pretty good aluminum in the masts for antennas like the DB-224. There have been thousands of those type of antennas installed several hundred feet above ground in some pretty harsh climates.
I use the bottom (just over) 1/2 as a gin pole. It will lift very heavy sections of Trylon free standing tower with out bending much. It always resumes it's shape. Make sure yours is the older mast with the 3 peices of tubing in the bottom, not 2. I think the older db-224s were built better and out of better stuff than the newer ones coming from south of the border.
73 Norm
"A man who has not mastered his temper, will find a quarrel anywhere" ~ unknown
TEA= Taxed Enough Already
I agree with Glen. The mast could be used for a larger yagi, if the antenna is mounted just over the thrust bearing or top of tower. DB-224's have done well over the years, though I have seen the masts bowed due to hurricanes in the South -- along the Mississippi coast while I was in the service years ago.
73, Steve, NL7W
Avatar: my Iditarod sleddog mutt - Yukon
"Saruman believes it is only great power that can hold evil in check, but that is not what I have found. I found it is the small everyday deeds of ordinary folk that keep the darkness at bay: small acts of kindness and love. Why Bilbo Baggins? Perhaps because I am afraid, and he gives me courage." - Gandalf the Grey, The Hobbit: An Unexpected Journey
http://spiritualpopcorn.blogspot.com...d-journey.html
how does this affect the performance of the DB224?
73.....JD
FISTS #3853,cc 455
SKCC # 1395,tribune #12
Ten-X 10103
NAQCC #501
Adversly, I'm afraid.
Basically, because you remove all of the elements from the DB-224!
Another thing...
You can drill all the rivits out and then slide the top half of the mast down inside the bottom half of the mast. There is some other peices of tubing in the bottom of the bottom half of the whole mast. Depending on the vintage of your DB224, they may be 1 or 2. If you have the older model, it will have 2. You will have to remove them to slide the top half all the way down into the bottom.
