ad: davisrf
Results 1 to 3 of 3
Thread: Astron RS-20m panel meter replacement
    Feb 2009
    Louisville, KY
    Default Astron RS-20m panel meter replacement
    I have an Astron RS-20M power supply that needs a new amp panel meter. While this isn't the greastest looking power supply, it works well....but I would like the panel meters to at least work.
    Are there direct replacements for this? Or can I find some digital meters that will work without too much re-engineering?
    Thanks!
    Robert
    KJ4JFT
    Have you tried contacting Astron directly for a replacement meter?
    [COLOR=#000000][IMG]http://jamespaulsarte.com/temp/ham/k2qi_latin.gif[/IMG][/COLOR]
    Mar 2006
    Newcastle, NSW, Australia
    The problem will be mechanical more than electrical; meter surrounds (bezels) tend to be different for each manufacturer and it's often impossible to find a match.
    I can't find a decent picture of your supply but it does look as if the bezels are "special".
    As QI says, try Astron.
    Electrically, replacing the meters with digital ones would be simple; we have been talking about meters here;
    http://forums.qrz.com/showthread.php?t=228654
    You would have to work-out how to attach them to the panel; a rectangle of black plastic could make a false panel to mount the digitals in; or mount the meters in plastic boxes and attach those to the panel.
