ad: wmr-top
Results 1 to 10 of 24
Thread: PC power supply conversion
    Default PC power supply conversion
    I've seen instructions online a few places for converting/using old PC power supplies for ham stations. Has anyone ever done this with reasonable success? I'd guess additional filtering may be required on the output as well as some method of keeping RF from getting back into the supply.
    Aug 2009
    Los Angeles, CA
    You need to draw something on the 5V rail to keep the 12V rail stable, like 4A using a 1.25 Ohm 25 Watt resistor.
    73, Jim AD2U /6
    I used to just run an old HDD off the one of the molex to keep the supply running, they usually shut down if there is no load on +5v. Other then that you short "power on",green, to ground to juice it up.
    KB3SDS
    Yaesu VX-6R - Nagoya Dual band HT Whip
    Yaesu FT-8900R - Dual Band Diamond
    Icom IC229H
    - 2m Mag mount+cookie sheet
    Icom IC706 - G5RV, AT7000
    www.kb3sds.com
    Aug 2009
    Carrollton, GA
    I have booked marked a site that uses like 6 Computer Power Supplys to make a tower, and to have like 30 amps from what it said.
    you can always find CPU Supplys from like the recycling dumps. etc Free
    http://w5jgv.com/tower_of_power/index.htm
    Chips all run on smoke. Inside every chip is a little tiny supply of smoke that keeps it running smoothly. When you screw something up and let that little puff of smoke out of that chip it WILL quit working. That's an etched in stone fact of life..
    A fine is a Tax for Doing Wrong, A Tax is a Fine for doing well.
    Screwing up is one of the best learning tools, so long as the only thing you're not learning is how to screw up
    May 2001
    Google St. Louis Switcher ... numerous articles have been written since this QST article.
    Copy of that article:
    http://www.angelfire.com/planet/als_...e_switcher.pdf
    IF you have an ARRL membership -- these articles are freely available to you!
    The St Louis Switcher
    May 2002 QST, page 35
    Matt Kastigar, N0XEU
    http://p1k.arrl.org/cgi-bin/topdf.cgi?id=101842&pub=qst
    Building the St Louis Switcher (sidebar to The St Louis Switcher)
    May 2002 QST, page 36
    Heron, George, N2APB
    http://p1k.arrl.org/cgi-bin/topdf.cgi?id=101853&pub=qst
    Technical Correspondence
    Sept 2003 QST, page 73
    Steven D. Katz, WB2WIK
    Re "The St Louis Switcher"
    http://p1k.arrl.org/cgi-bin/topdf.cgi?id=104757&pub=qst
    Jan 2004 QST, page 72
    Tasos Thomaidis, SV8YM
    More on the "St Louis Switcher"
    http://p1k.arrl.org/cgi-bin/topdf.cgi?id=369&pub=qst
    Mar 2006
    Newcastle, NSW, Australia
    VK5JST has written some very good notes on modifying computer power supplies;
    http://www.users.on.net/~endsodds/safe.htm
    I tried doing this with a 500W ATX power supply that supplied 34A (or at least that's what the case said) anyway I was using a FT-7800 and it powered on but when I keyed up even on low power it shut off so I don't think it quite works so well.
    73 - KJ6CLX
    Henry, Woodland Hills CA
    May 2001
    Stray RF will cause many switch-mode power supplies (SMPS) to "shut down".
    I think you will find that the 34 Amp rating was for the + 5 VDC rail, not the +12 VDC output. Some of these SMPS have an adjustment pot on PC board to raise the output voltage to 13.8 VDC.
    SMPS have HV inside (> 300 VDC) and while "state of the art" -- they are complex for the average amateur to understand or repair.
    Even though Linear Mode supplies are heavy (power transformer), they are far simplier for the average amateur to repair.
    I used the information on this web page as a starting point for doing mine...
    http://www.mbeckler.org/powersupply/
    The power supply I used is this one: http://www.newegg.com/Product/Produc...82E16817341020
    It has been discontinued (it has been a whole month since I bought it...) but there are likely similar ones available.
    I added 2 pair of powerpole connectors to the case (where the wires used to come through) which are attached to the 12V rail (17A).
    I use my IC-2200H on it and have had no shutdown problems.
    N0REK
    I'm thinking over the weekend i might build a breakout box with a female ATX connection on it. That way i can plug in any ATX PSU i have laying around and give me the connectors, meters, resister, ect i need in one shot.
    KB3SDS
    Icom IC229H
    www.kb3sds.com
