ad: AC6LA-1
Results 1 to 10 of 19
Thread: Steel Belted Radial System
    Sep 2001
    Grants Pass, Oregon
    Default Steel Belted Radial System
    Does anybody have a chart on the effectiveness of using Mark V Gain oil in conjunction with a Steel Belted Radial System? I read that using the oil in liew of water when mixing the cement to go inside the tire carcus you could get upwards of 25dbi on tires at least 750r15. Further, I have heard that old firestones are working the best b ut they have to be pre sell out tires.
    Any info would be apreciated but am looking for gain charts and such.
    Lee
    NI7I
    Is it April 1 already?
    Sep 2001
    Grants Pass, Oregon
    Who knows? I quit winding my calender in December when I retired.
    Sep 2006
    Didn'tcha hear? The Gummit got outta the Mental Health business. Let em all out and gave some of um Ham Licenses....
    Sep 2001
    Grants Pass, Oregon
    Quote Originally Posted by KB1NXE View Post
    And you are from which institution?
    Apr 2009
    Tempe, AZ
    Quote Originally Posted by NI7I View Post
    Lee
    NI7I
    As you can see, maximum saturation of the internal steel-belted radial field can be achieved by increasing the amount of Mark V Gain Oil in place of water when mixing your cement. Greater dispersional symmetry of the radiating field can be measured as the ratio increases from 25% (first image) to 100% (last image)...
    However, it is imperative that your balun be wound in the following manner! Failure to follow this important step will result in prohibitively high cross-loop foldback voltage at the tire bead, which will cancel out the negative null.
    Proper tire depth beneath the soil line is important. Better results are achieved with greater depth, as direct granular coupling will increase as you approach the water table. This is best measured at the twelfth negative harmonic relative to the cross-radiating frequency - see the appropriate chart for your harmonic.
    Apr 2003
    MI
    Quote Originally Posted by KE7WSH View Post
    As you can see, maximum saturation of the internal steel-belted radial field can be achieved...
    Isn't it "roadside gain " instead of "broadside?" Or maybe that's "gin," not "gain."
    BTW, well done, that.
    Cortland
    KA5S
    Sep 2001
    Grants Pass, Oregon
    Exactly what I was looking for. Thank you very much. I have been attaching my feedlimne directly to the portion of the tire that normally
    seals the tire to the wheel. However, I remember reading, years ago, about inductively coupling to the feed line. Any input on this?
    Lee
    NI7I
    Nov 2004
    Lee
    NI7I
    Actually, yes.
    If the tire is rotation specific, that is. Look for an arrow somewhere on the tire that indicates spin direction. Use the right hand rule for CCW rotation and the left hand rule for CW rotation when you wind your feed line coil.
    Mark, K8MHZ
    -W9JEF
    Kilowatt Alley
    Ancient stuff!
    Should use a synthetic oil!!
    -Otto Watt Sept. 5 1925
