Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Antennas on metal building?
  1. #11
    Commerce MI (Detroit area)
    Unhappy waste of a Yagi
    [QUOTE=WA4NMS;1721372]
    Quote Originally Posted by WA7IPM View Post
    I Don't think of metal as "sucking" RF, it will reflect and maybe redirect energy, but that can be a good thing as well as bad. It all depends on the spatial geometry of all the elements. You won't know until you try it.
    The whole idea of a Yagi is directing a beam of low angle RF toward the horizon.
    The metal roof , only a few feet below the ant will detune it to start, high SWR and a random bit of RF, left over, heading up into the sky.
    Not much use for working the higher HF bands !
    A vertical, on the other hand, will function just fine there, seeing a good ground plane is exactly what a vertical needs.
    73.....JD
    FISTS #3853,cc 455
    SKCC # 1395,tribune #12
    Ten-X 10103
    NAQCC #501
  2. #12
    Default antenna? what antenna...
    :I have a similar situation, only worse. I live in a senior mobile park that does not allow visible antennas, and all around are metal buildings and mobile homes. so far I have been able to hide a 80 foot loop in my carport, which is covered by shakes, thankfully, and is center fed with a sgc237. at least I get out. which is amazing there are mountains all around.
    KF7VZ
