Choke balun for 20M ground plane
I have a home brewed 20M ground plane about ready to be erected. I will be feeding it directly with RG8U. The ARRL Antenna book suggest I build a choke balun and provides an example of 6 turns of RG2313 on a 4 inch (diameter) piece of PVC pipe. Can anyone here advise me on what difference there might be if I use RG8U instead of RG-213? Would the amount of turns be essentially the same ? Also, since I have 2 inch diameter PVC pipe already, could I use 2 inch as the diameter for the choke? If so, how many turns would I need for that?
FYI. The antenna will be 1/4 wave above ground , around 17.5 feet. I am initially going to try with just TWO radials and see how it performs. Coax length will be around 75-80 feet.
Andy K3UK
Andy K3UK
Andy,
I'm not too sure of your coax type-designations over there in the US, but I believe RG8 is essentially the same diameter as RG213. If that's correct, you need the same number of turns. I doubt you'd physically be able to get it around a 2" former. You might also need to think about the insulation material and whether having it bent in a tight radius could cause "migration" problems.
By the way the ARRL Antenna book shows that 12 turns on a 4" former would put the self-resonant frequency close to 20m and give you a much higher choking impedance.
If I'm wrong about the cable diameters - apologies!
Steve
"In physical science the first essential step in the direction of learning any subject is to find principles of numerical reckoning and practicable methods for measuring some quality connected with it. I often say that when you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely in your thoughts advanced to the state of Science, whatever the matter may be." (Lord Kelvin 1824-1907)
If you can bend RG-8 around a 2" pipe you are a better man than I - that's too small - actually, I'd go 6" as a minimum diameter, 8" will also work fine - it's more a mechanical issue. The pipe is just as a form to wind the coil - you don't HAVE to leave it in there. 8 turns should do the job.
Tests have shown that having a neat side-by side wind on a form is MUCH more effective than a scramble wound coil, if that counts for anything.
You could also use a 1:1 UNUN in the application if you have a suitable toroid core for winding one.
You can also use 7-10 snap-on or slide on ferrite beads.
Duh ! I never thought about the bending issues
Thanks for the advice folks. Now off to think of what I have available that is 8 inch diameter.
Andy
Andy K3UK
Andy,
If you use 8" diameter don't go above 6 turns, otherwise 20m will likely be above the self-resonant frequency.
Steve
Andy K3UK
Well, the ground plane is up in the air !
One thing I worry about, the SWR is flat over a WIDE portion of 20M. I cut for 14.100 and SWR 1:1 there but about the same at 14.300. Sign of an issue or to be expected? It hears well. Europe a couple of S2 units over old dipole., which was my mission!
Andy K3UK
What's your vertical element made of? If large diameter tubing, it should be pretty broad-band - although that's enough to make me wonder as well, but you know what, if it's louder than your dipole, I think you know what the answer is.
Might as well run with it, if your tranciever is happy, and people hear you that's what counts right?
But don't leave the metal coffee can in the coils as something to mount them to.
6 turns of (hopefully) RG-213 wound on a short length of plastic sewer pipe or PVC as a form will give you excellent choking characteristics for 10 through 20 meters.
Not sure why anyone would worry about a good wide bandwidth and very low SWR.
-Otto Watt Sept. 5 1925
No, I did not leave metal can in there.
I called CQ and first QSO was with Iceland, second was Cyprus, all barefoot. So it works!
TF3HZ 12-Apr-09 1820Z Iceland 14.076 RST 59
5B4AIF 12-Apr-09 2001Z 14.156 20M SSB RST 56 14.156 Cyprus
215
EI6IZ 12-Apr-09 2211Z 14.004 20M CW 599 599 14.004 20M Ireland
Andy K3UK
