ad: Rohn-1
Results 1 to 4 of 4
Thread: Kenwood TS-430S TX power problems
    Unhappy Kenwood TS-430S TX power problems
    I have a Kenwood TS 430S HF that has low TX power, AM carrier goes to about 10W max and should be 50-60W, SSB upper or lower equal goes to about 22W on all bands. Current draw is close to normal for full output (17.5A). It appears also the fan circuit is not right because it should kick in on high and doesn't. Does this into dummy load or antenna and verified SWR on all antennas with other rigs. Several years ago I had one act similar
    and it was the fan control switching circuit. Already checked on this and that portion of fan circuit appears to be good. Any help with similar issues appreciated. All other functions are normal, excellent receive, tuning, turn on etc...
    KC8JQJ
    Maybe I posted this in the wrong thread?? I am just hoping someone has had a similar issue or recommend somewhere else to check. Any suggestions appreciated.
    KC8JQJ
    John
    Mar 2006
    Newcastle, NSW, Australia
    I don't know of any specific cause of this problem.
    There was discussion here;
    http://groups.google.com/group/rec.r...4d01e883971aef
    about power-loss and several solutions were offered.
    The well-known "finals" problem is covered here;
    http://www.somis.org/430.html
    Also here;
    http://forums.qrz.com/showthread.php?t=175184
    here;
    http://forums.qrz.com/archive/index.php/t-120316.html
    and here;
    http://www.g3ynh.info/commercial/TS430.html
    Thanks for the links VK2TIL,
    Some of the fixes described had already been done to this rig. I will investigate some of the others. I don't see anything about the fan. It is supposed to kick on high but doesn't right now.
    Thanks again
    KC8JQJ
