Mobile vs Portable, what is the difference?
What is the offical answer on the differences between Mobile and Portable operations? Where is the reference in the FCC rules?
In Part 97 there is no concern for portable or mobile operating any longer (in the usual sense) so there would not be any definition of those terms.
The lines of definition would be rather blurred these days.
I'd always understood that "mobile" would denote operation in or on a vehicle [naturally or mechanically powered], and "portable" would mean operation on foot.
73 de Mike, N5RLR
"To be is to do." -- Socrates
"To do is to be." -- Sartre
"Do be do be do." -- Sinatra
LICENSED 21 YEARS 1990 - 2011
here is how it was
portable meant just that
you were not at home
it was a station you had moved from someplace else
and would later move back to where it came from
example
seting up a Amateur Radio station at the summer cottage for two weeks
using a dipole in the trees
that would be portable
sitting at a camp site in the woods with a qrp lash up
hooked to a wire antenna or antenna you had to set up
a station mounted in a car, boat, airplane, motorcycle
or carried on your back
hooked to a mobile antenna that was mounted on the car, boat, airplane
motorcycle or your backpack
that can be used while moving
that would be mobile
there was a time when these thing realy meant something
in the 30's
you could not run mobile
without special permit from the fcc
on 160, 75/80, 40, 20,
you could run mobile on 10, 5, ect on up
for portable work
you had to send a letter to the fcc
telling where when you were going to be
dit
dit
Mac
Mobile is not just operating from a moving car, it is more than that.
Air/Mobile, M.Time/Mobile and so on, while portable is when you are station away from your qth and operating a portable set up, for example all of the A7 group plans regular trips away from the main cities and town and in an open un popilated area and camp their, with portable power sources and equipment, this is difined as portable stations, or some times like expedtions carried out under special occasions.
All of the best
I like to live in peace, die in peace and not into pieces !
Smile and the whole world will smile with you _ cry and you will be crying all alone!
Rashed A71AN/A71CW
Mobile/Portable
Agree that there is not going to be a concrete answer here. As a good rule of thumb, mobile requires an external power source (powered from car battery), portable has a battery built into the equipment.
In the military we used the following designations (still with many exceptions)
Fixed or Ground- Designed to be bolted to a rack and left in place
Transportable- unplugged, boxed up, and moved to new location
Mobile- Able to be operated while in transit from an external power source
Portable- Usable with internal battery (manpacks)
One definition:
Portable is a station moved to a fixed location and operated while stationary. A station in a big van, like an EMS field command station. Field day. Activating an island. Special event station.
Mobile is using the radios in your car, boat, plane, et cetera while driving.
in the 30's
I had a genuine set of the rules for amateur radio dated 1933 a few months ago.
It (as I understood it) did not allow for mobile operations at all other than aeronautical mobile. Thought that was pretty weird!
The rule book was pretty small. Not a whole lot of regulations! Not a whole lot of bands we could use then either!!
Interesting stuff!
During the first half of the 1930s mobile operation was not permitted and to operate portable you had to notify the FCC when you were operating away from your licensed location. In one of the major cities a group of amateur radio operators got together and each operator filed a notification of portable operation from every street intersection in the city. Reportedly each of these notifications involved over 100 type-written pages of documentation. Of course the intention was to use a mobile.
Within several weeks the FCC changed the regulations to allow mobile operation.
In years past one had to notify the FCC district office in which the portable operation was to take place as to the location and time frame of the operation before operation could take place. Then the regulations were changed to be if you were going to operate for more than 72 hours from a specific location (these regulations were in effect in 1960 when my family went on a 3-weeks vacation driving from Indiana to California via Arizona). During that time I had to notify the FCC Los Angeles office because we were staying at my aunt's house in Newport Beach for more than 72 hours. But, I did not have to notify anyone for my operation in Tucson, Arizona, because we were there for less than 72 hours.
Of course these days you do not have to notify the FCC of any portable operation if, for no other reason, there is no longer a permanent station location indicated on your license.
Just to add to the confusion -
I operate with an automobile battery,
not attached to an automobile. The
battery sits on the sand in the desert
next to me where I operate from a
lawn chair and portable, fast erect
antennas.
This portable/remote location is on my property,
on my ranch in Arizona. It is my QTH, and it is
portable/battery powered/relocated now and then.
"Backyard remote"
Craig 'Lumpy' Lemke
www.n0eq.com
