Results 1 to 3 of 3
Thread: Yaesu Rotator- G 450a
    Aug 2004
    Troy, Alabama 36079
    Exclamation Yaesu Rotator- G 450a
    I have a G450a Yaesu rotator. Everything works great except for the indicator. Any suggestion where to look
    Jim/W7QEB
    Jim/W7QEB
    May 2001
    Fresno, CA
    Default Yaesu Rotor
    Yes...most rotors have a pot inside which provides graduated resistance to
    make the direction indicator needle work.
    Chances are good that's what's wrong with yours. If you decide to disassemble the rotor to check that pot do your dis-assembly inside a cardboard box or plastic storage tub. It is often the case that ball bearings go everywhere when the case is pulled apart.
    I have heard bad stories about Yaesu rotor support ans even worse stories about getting parts and/or schematics. You might want to call or email Yaesu before you start the project. I don't believe the domestic rotor repair guys (Norm's et al) will work on Yaesu rotors. But it can't hurt to ask.
    Good luck
    Paul/W6VPS
    Also see post #9 in this thread...
    http://forums.qrz.com/showthread.php...ht=yaesu+rotor
    President - Shade Tree Mechanics-Rickety Welding & Let the Smoke Out Electronics Co.
    South Central Alabama
    Default schematic
    Jim,
    I sent an Email (QRZ address) with the schematic...... later sent another with a possible cause. Hope the fix is something minor.
    73 Bill WJ5O/BCN 28.289 MHz
