Results 1 to 3 of 3
Thread: help - cant edit HB9MQB details
    Feb 2008
    Immensee, Switzerland
    Default help - cant edit HB9MQB details
    Hi there
    I am not able to edit my profile:
    Error message:
    Update Access Not Authorized
    You lack sufficient privileges for this operation. QRZ rules for editing callsign information require that your login name be a valid callsign that already exists in our database.
    If your login name is a valid callsign that is not yet in our database then you must use the help of a volunteer who will be happy to update your callsign information. Once entered, your privileges will be instantly upgraded to allow you to make your own changes. We have set aside a special forum called the DX Helpers where DX callsign holders can find a volunteer who is willing to help. Don't worry, there are lots of friendly folks who are willing to lend a hand to get your callsign into the database.
    If you are a USA licensed amateur, chances are that the QRZ server has not yet received an FCC update for your callsign. If this is the case then you should wait until your callsign record appears on this site before trying to make any changes. If your callsign has recently changed, you may still be able to login under your old callsign
    Can anyone help?
    TNX
    73 de hb9mqb
    Beat
    Email: beat@hb9mqb.com
    Nov 2004
    Yokohama, JAPAN
    Smile Updated!
    Hello Beat HB9MQB,
    You have beeen updated to QRZ Member.
    Now you should be ok to edit your info yuourself.
    Please try it again.
    73, Kaz
