Callsign ad: hamtest
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 32
Thread: cb radios vs hf radios
ad: AmericanRadio-2
ad: L-grumpyshop
  1. #11
    Dec 2002
    Anyways I didn't get no answers to none of my questions.....
  2. #12
    May 2001
    Lakewood, WA
    Default There's a reason for that...
    DX Y'all,
    You got answers, and good ones too, you just did not get the answers you wanted or expected.
    Too bad...
    Most of the Hams will not give advice on this subject because the boiler plate about you eventually getting a license is something we hear a lot, and most of those guys never get a ticket, nor did they ever have the intent to get licensed. So, they are accordingly a bit sensitive on this question.
    KU0DM gave you an excellent answer, but again, you ignored that...
    So, good luck on your quest for the best freeebander radio. Just don't waste time trying to talk on ten meters. Stay on the frequencies below 28 MHz, and above 25 MHz and take your chances with the Feds.
  3. #13
    Quote Originally Posted by dxuall View Post
    hi have a question for you guys out there. what are the differences between cb radio gear and hf radio gear?? I understand hf radios have more bands and all that. also I know you need a licence to trasmit on the air. but how about power? what radio would get out further? what radio will have a better reception overall? what would you guys recomend? I am a truck driver and I am interested on hf radios to listen to hf at night and later on become a ham operator. what can you listen at night on hf? let's compare a galaxy 95t2 radio with 240 watt output vs a yaesuft-857d with 11 meter band any coments would be apreciated thank you. juan.
    Actually you did get answers.
    If you mean 'transmitting on CB frequencies within the US and it's territories' by "what radio would get out further?".... then you did get your answer there. It's not legal to transmit on CB frequencies with either radio.
    As for reception. the following is a good answer:
    The Galaxy would be at the low quality end of the spectrum; it wouldn't have the real features desired or needed (variable IF filter bandwidth, IF shift, etc.) in the Amateur world. the "240 Watts" is probably overstated as well. In addition, Amateur Radio quality radios will have continuous tuning ability, rahter than relying on "channels" or switches to move around a band. In addition, 99.44% of "Amateur Class" radios will cover more than one "band," and current models have continuous coverage from (at least) 100 kHz to 30 MHz. give or take a few kHz.
    For transmitting on CB, you're going to need a dedicated, legal CB radio. The Galaxy you were talking about, or any other radio that puts out more than 4 watts AM / 12 watts SSB is not going to be legal. There are probably people that transmit on CB with amateur radios, but I don't think you'll find too many people on here that would suggest doing that. We like having our licenses too much.
    In the end, you'll probably end up with two separate radios, or more. One that can do everything with amateur radio and is a small unit is the Icom IC-7000. As just a receiver it might be a bit pricey for now, but if you're really serious about becoming a ham, the IC-7000 will receive a large number of bands, and will serve you well later once you become licensed to transmit.
    If you're looking to just receive for now and then buy a transmitter later, the Yaesu VR-5000 looks to be a very nice receiver.
    And now for something completely different...
  4. #14
    I actually typed up a answer to this, but I think it would be a wasted point.
    Never mind.
  5. #15
    They say the galaxy is junk, but actually it excels at AM where it is intended to be used. Todays HF rigs aren't primarily intended to be used on AM. The galaxy provides what truckers want: Loud AM. The 857d you mention works functionally fine on 11 meters (after the mars mod), but it doesn't work there in the legal perspective.
    If you used a single HF rig for both ham and CB, you wouldn't be "loud & proud" on AM the way truckers want to be. The ham rigs surpass all those CB radios on SSB, not not so on AM transmit, tubes aside.
  6. #16
    Mar 2005
    Flint, MI
    Don't let these guys mess with ya. They just see an chance to mess with a CB'er but they forget that a lot of us started on CB. I also am a truck driver and I understand the questions that you are asking. Instead of welcoming you to such a great hobby, they would rather hastle. Thats sad.
    But here is the skinny of it. Most people in general do not understand ham radio and its difference from CB. Because of this, companies use it to there advantage to sell illigially modified CBs under that ham radio banner. These you can find all over truck stops and cb shops labeled 10 Meter radios, but they are not ham radios. 10 Meters is very close to CB in frequency, so they open them up and sell them as "10 meter" radios. No ham would ever use one of these radios on 10 meters for many reasons. They do not have the sensitive recievers or filters needed for our use being the largest. Not only that, but for the same price, we can get a radio that not only does 10M, but also 12M, 15M, 17M, 20M, 30M, 40M, 60M, 75M, 80M, and 160M. Its no contest between the quaility. That being said, those radios do what they were made to do excellent (even if it pisses some of the guys off here, its the truth) and thats being good CBs. They were never intended to be Ham Radios.
    Getting that out of the way, will help me get to your questions better. As for power out when it comes to reception.... It has no bearing at all. Power only assists you on transmit. Most HF radios come standard at 100 watts. Now, the fella's told you all about how that galaxy is illigael power. Anything over 4 watts is.(Ham Radio operators can use up to 1500watts on most bands) But you know this, so lets just use it as an example. Your normal condition contacts go from maybe 3 miles up to 10-12 miles with all that power right? With less then half that power on an HF rig, you can talk the world with ease. THATS the DIFF! Hands down, HF radio is a whole new animal then CB.
    Now for what you can hear. Let me break it down for you.
    10M is long haul world wide daytime communications. You will here signals from Europe and Africa during the day, and Australia and Japan in the evenings (Saying I am in Michigan). Unfortunately it is effected by the solar cycle a great deal and it is dead as a doornob right now. Good news is we are on the way up again in a few months. Closes up at night and open in day.
    12M Much like 10M
    15M A bit more reliable for sustained worldwide communications and not effected as much as 10 and 12, but still pretty bad low cycle. Closes up at night and open in day.
    17M Great Nationwide to worldwide coverage. Great mobile band. Nice place to talk and talk and talk from coast to coast. Closes up at night and open in day.
    20M One of the most popular bands in ham radio. Much more reliable for sustained coast to coast communications. Worldwide communications even in the low cycle. Many directed nets (controlled frequencies) dedicated to everything from clubs and subjects to mobile service nets. A lot of truckers hang out on 14.300 which is dedicated to ships at sea, but also road travelers nationwide. Another is 14.336 which is county hunters. Truckers are loved here as they give out counties to people that collect contacts like baseball cards. Pretty much closes up at night and open in the day.
    40M has two skins. In the day its a regional (cluster of states) chit chat band that has its own mobile service frequencies and at night opens up to the nation and then the world. It opes so much at night, that becouse we have different privlidges then the rest of the world, you will here broadcast on this band from around the world. It can be really noisy and harsh on the ears in the mobile I think, but a lot of fun.
    75/80M is also regional during the day and opens up at night. But think of it to much more extremes both ways. In the day, you can talk closer in, and at night, you can work even further. I think its much more pleasent to listen to in the truck with LOADS of chit chat groups and directed nets. THIS is were you want to be at night in the truck. Find a good group and make yourself at home.
    This does not even include talking about VHF/UHF with its FM (not to mention GPS Data location APRS or satellites) local freq's.
    This is a very broad representation, but you get the point I hope. One thing to consider, the lower the band (higher the freq) the smaller the antenna. SOOOO..... Day bands are easier to go mobile with and the night bands are a bit harder to do it right. Biggest thing to remember is GROUND GROUND GROUND and dont forget that at 80M, you are compromising what should be 200ft of antenna into a 4-6 foot package.
    I dont know what I would do out here without ham radio. I urge you to ignore these fellas that get carried a way online. It is not what you will encounter on the radios. It is really sad sometimes how the community looks via just QRZ. If you do get your license, you will understand there posts of sarcasm and poking much better later.
    But first step is first, you have some studying to do. The good thing is it does not cost anything to get licensed other then a paperwork fee persay which is under 20 bucks I think at most places. You pay it when you take an exam. There are three classes of license.
    The first is Technician. This is basic rules and regs along with some really easy theory. Its very easy to attain. Get a book from a store you can order from like borders called "Ham Radio License Manual". Get the latest edition you can find. I think its still the first. It use to be called something else, so its still 1st edition. It is a real easy read. After you get this license out of the way, you can enjoy all the local VHF and UHF stuff. You can use repeaters that make your truck put out a base station signal, sometimes over 100s of miles. Oh, and say good bye to the noise of AM CB. These radios use FM just like you hear on a police scanner. There is so much more you can do, but thats what most people start with.
    After that, you will want to get started studying for the General license as you get to know the hobby via the Tech and its VHF/UHF abilities. Once you get your General (which is more rules and regs and deeper into theory) you will then gain the majority of HF Privlidges. Thats were you want to be.
    After that comes Extra. Much more technical of an exam. You can concentrate on that well after you get addicted.
    I hope this helps. Email me anytime at wc5b@yahoo.com , If you do, I will give ya a number to call if you have any other questions. Welcome to the hobby. By the way... There is NOTHING AGAINST THE LAW about having an HF radio and just listening to it. Nothing wrong with this at all. I would recommend it to see how we tic. Just DONT transmit. You may not think so, but it is easy to spot and easy to track, and unlike CB, Ham radio is enforced. Fines up to 10,000. Its not an uppty up thing, its a pride thing. Not only that, but we can lose these rights and privileges if abused.
    (As for an 857, Its very small and I would not suggest you run it in a truck. Menu system is very complicated to keep it small which is distracting, and its hard to see. I would suggest looking at radios like the Alinco DX-70 or Kenwood Ts-480, but a lot of guys run Icom 706s and 7000's which are great mobile HF rigs but still suffer from menu difficulties. Another thing, these radios dont ship opened for CB and I would not advise doing it. Most of these modifications when done, effect the receivers. Not only that, but believe me, you wont be worried about CB once you do the other bands. Nobody believes me, but it happens every time. Trust me. Just have a basic CB in addition. They do the job better anyways, its what they were made to do. I run my HF rig, my VHF/UHF rig, and still have plenty of space for my CB cobra 29)
  7. #17
    Nov 2003
    Another point is,…{this may come as a shock to some so sit down and get a grip}
    11 meters is HF.
    At one point in time it was a amateur radio band.
    The FCC took it away from the ham community in either the late 50’s or very early 60’s
    There are still some amateur transmitters in existence that have the 11 meter band in them.
    WC5B gave you a lot to think about.
    Do some reading, learn some stuff, take the test stay legal, have fun.
    KA9VQF
  8. #18
    Feb 2003
    Wonderful WYOMING, Accept no substitutes.
    DX U ALL??? Maybe me smell a troll.
    "Life is just like ridin' broncs, its a battle". Chris ledoux
  9. #19
    McIntosh, NM
    I recommend you stay on CB where illegal operation is the norm. Leave ham radio alone.
    Ed, CHOP, W5HTW - Novice 1956, General, 1957, Advanced, 1968, Extra, 1969. Keep the amateur in amateur radio, keep the pros, and Part 90, out of it.
  10. #20
    Feb 2005
    Barberton, Ohio
    Quote Originally Posted by KC7YRA View Post
    Sad no one else did...
