Results 1 to 2 of 2
Thread: Getting JLog to update frequency
    Oct 2007
    St. Peter, MN
    Default Getting JLog to update frequency
    Hi,
    As some of you know, I just switched to Ubuntu Linux full time. I decided that instead of using Ham Radio Deluxe under wine, I would try some of the native Linux alternatives.
    After much fooling around, I got the hamlib rig control library and Xlog working. However, I don't really like Xlog, so I'm trying out Jlog. It seems like a good program, but I've been having problems with the rig control. I've got it set up, and when I start Jlog, the correct frequency is shown. However, if I change the frequency, Jlog never updates.
    If I click a spot in the DX cluster, it will change the radio to that frequency. It still won't update the frequency readout.
    Any thoughts?
    Isaac
    Isaac, 17, St. Peter, Minnesota
    The only two tools needed: WD-40 and a roll of Duct tape.
    If it moves and shouldn't you use duct tape.
    If it should move and doesn't you use WD-40.
    Might be a UBUNTU problem.
    Have you tried one of the 100's of other distro's available for free downloading ?
    I personally prefer Suse 10.3
    No I personally have not tried Jlog but I just might give it a go.
    I have PUPPY Linux with Fldigi running and my paper log book is working perfectly.
    Good luck with your venture into Linux for HamRadio
    Howard
