Results 1 to 10 of 14
Thread: fl-2100b doorknob caps
    Mar 2006
    Hilton N.Y.
    Default fl-2100b doorknob caps
    Need a 1000pf doorknob capacitor. it calls for 3k caps. Could I use a cap with bigger voltage ratings or does it have to match perfect?
    [SIZE="5"][COLOR="Red"]73, WB2BM[/COLOR][/SIZE]
    Thumbs up
    Should be an "off the shelf" part from RF Parts.
    http://www.rfparts.com/
    Tell them you need the part for a Yaesu FL-2100b amp, and they should be able to get you right part.
    Other choice is "hit or miss" at dwindling hamfests, eBay from Chinese/Taiwan mfg. / suppliers or the surplus stores (Surplus Sales of Nebraska and others across US).
    Apr 2006
    Bristol, MD
    If you have a cap with a higher voltage rating, it should work just fine, IF IT WILL FIT!!!. But try to keep the capacitance about where it's spectd to be. (~1000pf). I assume by 3K you mean 3KV.
    Mar 2006
    Hilton N.Y.
    Thanks for the info I'll check RF parts. I see lots of 1000pf caps none with 3kv ratings they range from 4kv and up..
    Brian,
    A voltage rating higher than 3 KV is OK ... BUT you want to check the size --
    if clearances are an issue for your amplifier.
    I see in Carol Maher's notes (Fox Tango) that your part (C222) is:
    Yaesu part number: K24356102 - RDA30 3 KV
    Check with Yaesu parts or Carol for that part as well as RF Parts
    Scroll down to FL-2100b photos for a specific photo of that part:
    http://foxtango.org/amplifiers/FL%20...0Evolution.htm
    HT-50 / 58 Series
    Ceramic doorknob. 0.813 inches diameter,
    0.89" long. 6-32 UNF thread.
    HT-50 series at Surplus Sales of Nebraska
    http://www.surplussales.com/Capacito..._doorknob.html
    HT-50 series at RF Parts
    http://www.rfparts.com/caps_ceramicdoor.html#ht50
    Yaesu FL-2100 Technical Bulletin - when using Svetlana (SED) 572B tubes
    Bias Level Adjustment kit is ONLY $ 2.50 from RF Parts!
    http://www.rfparts.com/technical.html
    IF you want to buy the Chinese product, look at eBay item number: 250234992793
    1,000 at 15 KV .. measurements 30mm diameter, 21mm height.
    Jul 1999
    New Jersey
    Quote Originally Posted by kc2pkk View Post
    How do you like that amp ? I'm going to look at one this week that I will probably buy.
    Dave
    WS2L
    Senior Database Administrator/DX Help Desk Administrator
    I'm going to look at a FL-2100b amplifier this week that I will probably buy.
    Dave -
    If you are going to purchase a Yaesu FL-2100b, I would recommend listening to Steve (WIK) comments as well as those of Carol Maher at FoxTango.
    Scroll down to the FL-2100b section of the Yeasu amplifier page at FoxTango, where Carol provides service comments with photos.
    A common problem is the band switch on these units. Yaesu released a service bulletin (CA:128) on this issue in 1977.
    http://www.foxtango.org/amplifiers/F...0Evolution.htm
    In addition, since most amplifiers of this vintage are now 30 years old -- some common sense maintenance and updates are highly recommended.
    1. Replace high voltage electrolytic capacitors
    2. Clean bandswitch, fan and inside of amplifier
    3. Check R207 (47 Kohms), see Carol's notes
    4. Check C222, photo here (K24356102 - RDA30 3 KV):
    http://www.foxtango.org/amplifiers/g...B%20Finals.JPG
    5. Check RFC, here are side-by-side photos of a destroyed RFC on left and new one on right.
    http://www.foxtango.org/amplifiers/g...20Overhaul.jpg
    Feb 2005
    Barberton, Ohio
    If RF Parts doesn't have what you need in stock, PM me. I just picked up half a dozen or so at our last area hamfest...
    Mar 2006
    Hilton N.Y.
    Quote Originally Posted by WS2L View Post
    I like the amp so far. Got it off of ebay. Aside from the #222 cap being cracked. Very easy to work on, lots of room inside.
    I just got done cleaning and oiling the fans. They probably didnt need it as there was hardly any dust on or in them, but they got some fresh oil and do spin faster now. The band switches are still in good shape and it has cetron tubes (could be original). Puts out 900+ watts, I dont want to push the cap to much till I get a new one installed. Its also wired for 110v. I do plan on running a seperate 220 line for it. Also plan on getting 2 new tubes and packing up the old ones as spares. Hopefully it does me right..
    Brian
    Mar 2006
    Hilton N.Y.
    Quote Originally Posted by n8yx View Post
    Thanks n8yx,
    I will know monday when I call thanks for the offer!!
