ad: SteppIR-1
Results 1 to 1 of 1
Thread: Icom 2350
    Default Icom 2350
    This Icom IC-2350 has worked great for me for years. It is modified for extended TX and will work as a cross band repeater (Please use only at frequencies that you are authorized to transmit on) one of the knobs fell of in my truck and I lost it, as you can see in the picture I would rate it an 8 out of 10 cosmetically It works great and always has. It a good rig it comes with the original mic and power cord. If you have questions my phone number 928 221 7453. Asking $225 plus shipping John H AB7LT john@myradioplace.com
    Type: Amateur VHF/UHF transceiver
    Frequency range: TX: 144-146 / 430-440 MHz (Europe)
    RX: 118-174 / 320-479 / 830-950 MHz
    Mode: FM
    RF Power output: Hi: 50/35 W
    Mid: 10/10 W
    Lo: 5/5 W
    Voltage: 13.8 VDC
    Current drain: RX: Max 1.8 A
    TX: Max 11.5 A
    Impedance: 50 ohms, SO-239
    Dimensions (W*H*D): 140*40*204 mm
    Weight: 1.2 Kg
    Manufactured: Japan, 1995-199x
    Other: 110 memories. Twin RX
    This ad was posted by AB7LT JOHN A HERRING, COTTONWOOD, AZ 86326,
    AB7LT joined QRZ on: 02-10-2006 IP: 184.101.100.203
    If no email address or phone was given, click HERE to send AB7LT a private message.
