Results 1 to 3 of 3
Thread: MFJ 259B Antenna Analyzer Help with traps
    Wonder if anyone can help me with this. I want to make some antenna traps using my mfj 259B. But not sure how to used it as a grid dip meter. Has anyone done this?
    Or just the best way to used this analyzer to make trap.
    I'm just not understanding the manual.
    thanks much
    Feb 2002
    Right here
    I bought the grid dip kit with mine and it does work although not as well as my old Heathkit GDO does. Simply wind a coil of about 10 turns on a pill bottle and hot glue the windings. Remove the pill bottle and use an RCA plug (phono) to plug into the 259B. It requires a bit more coupling than a Grid dip meter but the SWR meter will dip when you hit resonance.
    South Central Alabama
    Keep in mind that every combination of capacitance and inductance will result in a resonant frequency ...... In series the result will be minimum resistance (reactance) .... in Parallel the result will be maximum resistance (X resonance)........
    I made My forty meter traps to be parallel resonant at 7.200 MHz
    73 Bill WJ5O/BCN 28.289 MHz
