Results 1 to 4 of 4
Thread: Protection Circuitry ?
    Unhappy
    I have the Yaesu FT-817ND and it comes with the battery tray (FB-28) to use 8 AA Alkaline batteries.
    I just bought 8 rechargable AA Ni-MH batteries and THEN decided to read the manual which states the following:
    Do not attempt to use Ni-Cd or other rechargeable cells in the FBA-28, because it does not contain the protection circuitry required when using rechargeable
    cells.
    DAMN!! What circuitry is there for alkalines but not rechargables?
    I do not plan on charging them in the radio. I have a seperate charger for that.
    I am cornfused
    Is there no way I can use the rechargables with this rig?
    The universe is a pretty big place. If it's just us, seems like an awful waste of space.
    Aug 2005
    I'm PRETTY sure they are just warning you not to try to recharge the batteries while installed in the rig...i.e. hooking up your 12 volt supply to the rig and expecting a recharge. I seriously DOUBT that installing precharged NiCads in the thing will hurt a thing. Voltage is voltage.
    BUT I COULD BE WRONG. Maybe someone else will have something to add.
    73, Heath/KE5FRF
    EchoLink Node#268023
    W5YI-VE
    Feb 2005
    Orlando, Florida
    You will find your answer here:
    http://www.w4wb.com/Manuals/FT817-FAQ.pdf
    73 de N4CR, Phil
    Dec 2004
    Shropshire, UK, SY10. Locator IO82LS
    NiCad and NiMh cells have a much lower internal resistance than alkaline so in the event of a serious fault something might fry. I suppose this implies a suitable fuse somewhere.
    As far as charging them goes, you need to limit the charging current. An excellent and simple constant current regulator can be made from any 3-terminal regulator (12V for example). I think the National Semiconductor website still provides this somewhere, it's just a regulator and 2 or 3 resistors.
