ad: giga-rw
Results 1 to 10 of 10
Thread: HF Multicast OnAir Now
    I turned the station on at 22:30 UTC and will operate for a few hours.
    The signal is in PSK63 mode, on 14.072 USB at 20 watts from the southern tip of Texas.
    I am sending a couple of short messages about the AltCast test transmissions, one in text and one in html, and an ARRL propagation bulletin.
    Any program that can operate in PSK63 mode should be able to copy the data stream. DigiPan and MixW will do it.
    Here is some information, including how and where to get the free AltCast software that captures the multicast data to your hard drive.
    Signal reports are greatly appreciated. Report here or use my email button below. #Best of all, report as requested in the information bulletins being transmitted.
    Anybody with AltCast capture a file, or have the HTML pop up in the mini-browser?
    Thank you!
    73 DE Charles, N5PVL
    The "S" word... It's not the socialism, it's the stupidity behind it.
    I'm downloading the software now. I'll try it until just before 6PM local and then I'm going to break for the NA Sprint.
    We've been smeckledorfed!
    OK< up and listening. I copied a 6 land signal to the low end on _SK31, but nothing else so far other than some odd digital signal that I don&#39;t recognize.
    2352Z and I got
    Quote Originally Posted by [b
    Quote[/b] ]8 39> year&#39;s number predicted, instead of a kno based on
    ithe actiaa sun7DTA 17 128 uary 2006 through January 2007,
    and the predic. kewµA 18 128 246>r for§ovebeth the redicted numb<DATA 19 128 10d sunspot number
    for December 2007, t eesbe
    based on the predicted monthly values for June 2007 through June
    2008, all averaged together.
    The predicted smoo<DATA 21 128 218>thed numbers from that table, for August 2006
    through December 2007 are 15.4, 15.2, 14.0, 12.4, 11.5, 11.2, 11.0-
    1 10, <DATA 22 128 163>11.1, 11.3, 12.0, 11. , 13.3, 15.6, 18.3, and 21.3. As
    =o can seeat differene hidher kfor rF
    fropagatile<DATA 24 128 245>, t
    using my IC-703 and Hustler 6-BTV. I&#39;m going offline with this now so I can get ready for the NA Sprint.
    Feb 2004
    Perry, GA EM82dm
    I never could get Digipan to see any PSK63 signal... lots of PSK31, though.
    Jul 2006
    Fairfax County, Virginia
    Same here. No PSK63 seen at that frequency or anywhere in the vicinity. Listened between 23:40 and 24:00 UTC.
    Thanks guys, all reports are useful because I&#39;m trying to figure out where the signal does and does not go.
    It looks like KC9ECI copied a part of the ARRL Propagation bulletin, but the signal never made it to 4-land.
    Thanks again, I&#39;m shutting down for the evening at 00:36 UTC.
    Ya gonna try again in the future, Charles? "Inquiring minds want to know&#33; &#33; &#33; "
    Do let us know, and I&#39;ll listen again.
    I got the station up again at 22:30 UTC on 14.071.5 USB ( according to my rig, you know how that goes ) in PSK63 mode.
    I kind of sandwiched myself in - between the PSK31 and MFSK signals.
    I&#39;ll notify here before I shut down, probably in a an hour or so. - I have to shut down around 6:45pm CST for sure, as I will need the computer then to transmit NewsLine on the local repeater, something I do every Sunday evening.
