Your average band noise smeter reading on HF
Discussion in 'Ham Radio Discussions' started by N0SYA, Apr 7, 2012.
  1. N0SYA
    N0SYA Ham Member QRZ Page
    Hi!
    I am interested in finding out what zedders face as far as typical/average no-signal condition smeter readings are with simple wire antennas such as dipoles and loops. Just band noise. And also if zedders employ internal or external rx amplification. Any input appreciated!
  2. KJ3N
    KJ3N Ham Member QRZ Page
    As of 11:30 local time:
    160m: On the only 160m antenna I have; S7.
    80m: On the 134 foot doublet; S4. On the 75m wire vertical; S6.
    40m: On the 40m loop; S2. On the 134 foot doublet; S1.
    20m: On the 40m loop, or the doublet; S1.
    15m: Doublet, or 40m loop; S1. On the 4-element 15m beam (pointing South); S2.
    10m: Loop or Doublet; S0. With the pre-amp on; S1.
  3. NN3W
    NN3W Ham Member QRZ Page
    I do not use external pre-amps. On my EDZ i get S0 to S1 on 10 to 20 meters. S3 on 30. On my 80 quad I get S2 on 40, S3 on 40 and S6 on 80. The 40 meter delta array yields me S2 on 40.
  4. NN4RH
    Depends on how I set my attenuators, pre-amps, and RF gain, and which antenna I'm using. Could be anywhere from S0 to S9+
  5. KJ4VTH
    KJ4VTH Ham Member QRZ Page
    Highly variable on this G5RVjr near the airport. Today 20m is very quiet S0 with intermittent S3 static crashes with lots of activity on the band. 10m is S4 noise and no strong stations heard. 40m is S3 noise and very few stations.
  6. KJ3N
    Yep, that was helpful. :rolleyes:
  7. N8YX
    N8YX Ham Member QRZ Page
    S3-S5 on the TS-940S/6BTV (20M), S7 on an IC-751A/80-15M inverted V (80M), S5-6 on another IC-751A/G5RV (40, 20M), S2 on a CPI2000/4BTV (11M) at the moment. I'm not running the internal preamps on any of the Icom gear, nor do I have the CPI's external preamp activated.
  8. KL7AJ
    It's usually very quiet here. Even though I have high tensions lines running along two edges of my lot, I've never heard a peep of electrical noise, even on 80. We do have a lot of weird "natural" noise up here at times...."Auroral roar" ans such, that can dominate on 20 meters.
    Eric
  9. W9OE
    W9OE Ham Member QRZ Page
    My worst band by far is 40 meters. Some nights I can have an S7 noise level about 40% of the time. I do use the internal pre-amp always. 20 meters and up are never a problem. I do live in the city so I would expect a little noise from time to time. It is just something you have to adjust too and learn to work around.
    I resent weeks I have had a lot or noise in the form of static crashes due to all the storms down round Tenn. I sure wish they would keep their noise to them selves down there.
  10. PE1RDW
    PE1RDW Ham Member QRZ Page
    on my ts 680 with a g5rv one leg hanging loose on the ground facing NE no amp att active
    160 m S3
    80 m S2
    40 m drowning in contest stations right now but just below 40 m S1.5
    30 m S5 pulse noise
    20 m S1
    17 15 12 and 10 m S0.5 - S1
ad: cq2k-1
