Yaesu vx-7r factory antenna setup
Discussion in 'Ham Radio Discussions' started by KD2ANB, Jan 1, 2013.
ad: K3QNTad-1
  1. KD2ANB
    KD2ANB Ham Member QRZ Page
    VX-7R FACTORY ANTENNA SETUP
    What is the correct way to put this antenna together for normal use. Do you leave it together for all bands? Thanks Ron
  2. K7MH
    K7MH Ham Member QRZ Page
    For 2 meters and the 440 band you use the bottom section only. Add the top section for using it on 6 meters.
    If you don't have a manual for it, you can find it with a quick search.
  3. N2ADV
    N2ADV Premium Subscriber QRZ Page
  4. KD2ANB
    Thanks all
    Do we assume for 220 we use only the bottom section? It also says you can use the two section for higher frequencies also. Thanks all Ron
  5. KJ4VTH
    KJ4VTH Ham Member QRZ Page
    I use bottom section with the short stub for 2m and 220.
  6. KD8COO
    KD8COO Ham Member QRZ Page
    My understanding from reading the manual is that the main section plus tiny stub are good for 2m/220/70cm. Replace the tiny stub with the bigger end for all bands. If I'm misunderstanding the direction, somehow I haven't blown it up yet running it this way. :)
  7. KD2ANB
    Thanks very much. I found today that I did better on 220 with the two large sections. It hit the repeater better on 220 than it did with the bottom and small cap. Thanks again Ron
