ad: QSKLLC-1
Yaesu FT2-DR / RT Systems / SD Card Programming
Discussion in 'Amateur Radio Software' started by W6TAE, Dec 17, 2017.
  1. K9JRI
    K9JRI XML Subscriber QRZ Page
    I realize that this thread is a bit old but I am waiting for my FT2DR to arrive and have heard that Class 10 SD cards are a problem for the FT2DR. It was recommended that I use an older format Class 4 SD card.
    Was this an issue or have 32G Class 10 cards been satisfactory in the FT2DR?
    73 - Mike - K9JRI
  2. KD2RHT
    KD2RHT Ham Member QRZ Page
    For some reason my FTM-400xdr does not see the SD card (option grayed out in Setup Menu), but tried another brand and it is fine. Both 16GB, PNY not found Lexar no problem.
  3. N5IKD
    N5IKD XML Subscriber QRZ Page
    As for me, I can use the DISP button and the knob to navigate the menus, but when I try to accept a read or write operation to the SD card using the DISP button I get two beeps and the radio does not perform the operation. However, if I use my finger on the touch screen to accept the operation : "Read? OK / CANCEL" then it works fine. Perhaps accepting a read or write operation with the DISP button was never a working feature. As long as the touch screen works you should be fine.
