WSJT-X not decoding
Discussion in 'Working Different Modes' started by W8WV, Sep 6, 2018.
  1. W8WV
    W8WV XML Subscriber QRZ Page
  2. W8WV
    FINALLY......had to change mode from USB data to USB! and right freg mode! THANKS K3DCW
    K3XR and K3DCW like this.
  3. W4NNF
    W4NNF XML Subscriber QRZ Page
    Triple check that the soundcard setting in WSJT-X is the same for receive and for transmit, and that you've selected the correct sound card (depending on your setup).
  4. W4NNF
    HRD isn't involved in the decoding part of the equation, just rig control.
  5. N1CTO
    N1CTO Ham Member QRZ Page
    Here's an explanation of how to set the mode you need . http://g8yph.blogspot.com/2015/04/digimodes-on-yaesu-ft-450d.html?m=1
    Just remember when you want to use non digital modes you need to set it back to RTTY.
  6. VE7LJL
    VE7LJL Ham Member QRZ Page
    I have same radio and scu-17 and a windows 10 laptop. WSJT-X version 1.9 it was decoding then quit so I uninstall the 1.8 version and reinstall 1.9 version now with the audio set to usb codec the waterfall signals drop off to nothing even with 40+db . and no decode I am ready to throw it out the window, I have tried all suggestions ..
  7. K0UA
    K0UA Ham Member QRZ Page
    Dont, give up and don't suffer in silence.. Call me (send an e mail (look it up here) and I will send you my cell number. ) Load teamviewer 13 and have manual to rig handy. We WILL get you going. I have helped dozens to get on the air with WSJT-x. I can help you too.
    James Baxter K0UA
  8. N3DT
    N3DT Ham Member QRZ Page
    I have found my version1.8.0-rc3 of WSJT-X sometimes will not decode even though I see traces in the waterfall. Sometimes I have to re-start it, sometimes I change modes and then back and then it starts. I get a few other little glitches too, especially when changing bands and it's not connected to CAT, but I just have to keep an eye on what it's doing.
  9. KD3WB
    KD3WB Ham Member QRZ Page
    Make sure your computer clock is accurate to within a second or two.
    https://time.is/
    Ben
  10. N3DT
    It's not my clock. That works fine, although I see others once in a while that are more than a second off. Once in a while I see a station that just will not decode, I can see on the waterfall their clock is way off.
ad: qroparts
